Hi Will,
It would help to have some more information.
Linux or Windows?
ADPointGrey, ADSpinnaker or ADAravis. Which version of the driver?
What version of the SDK?
What model camera?
Can you describe an exact sequence of events which triggers the problem?
Smith, William via Tech-talk
Sent: Monday, November 15, 2021 11:39 AM
To: [email protected]
Subject: Help with Blackfly FLIR/PointGrey Camera
I am trying to set up a point FLIR Blackfly camera using the point grey areaDetector support module.
I am able to connect to the camera and take images using the supplied SpinView Software. I am able to connect to the camera using the point grey area detector IOC. I can take 1 image in single mode, multiple images in
multiple mode, or as many images as I like in continuous mode. However, after 1 or two images in single mode, or the group in multiple, or if I press “stop” in continuous mode, I cannot take any more images.
In the IOC I get the following error at the end of the acquisition (in any mode) if there is an error.
epics> 2021/11/15 17:23:46.394 pointGrey:stopCapture: ERROR calling StopCapture Type=35 Description=Error stopping stream.
If it’s relevant I have packet size set to 1440 (I am not using jumbo frames)
Has anybody seen something similar? Can I enable some additional debug to get more information? Is there some additional configuration of my network card I should check?
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
