Subject: Help with Blackfly FLIR/PointGrey Camera
From: "Smith, William via Tech-talk" <[email protected]>
Date: Mon, 15 Nov 2021 17:38:34 +0000
I am trying to set up a point FLIR Blackfly camera using the point grey areaDetector support module.
I am able to connect to the camera and take images using the supplied SpinView Software. I am able to connect to the camera using the point grey area detector IOC. I can take 1 image in single mode, multiple images in multiple mode, or as many images as I like in continuous mode. However, after 1 or two images in single mode, or the group in multiple, or if I press “stop” in continuous mode, I cannot take any more images.
In the IOC I get the following error at the end of the acquisition (in any mode) if there is an error.
epics> 2021/11/15 17:23:46.394 pointGrey:stopCapture: ERROR calling StopCapture Type=35 Description=Error stopping stream.
If it’s relevant I have packet size set to 1440 (I am not using jumbo frames)
Has anybody seen something similar? Can I enable some additional debug to get more information? Is there some additional configuration of my network card I should check?
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
RE: Help with Blackfly FLIR/PointGrey Camera Mark L Rivers via Tech-talk
Prev: AppImages for EPICS base Zhang, Tong via Tech-talk
Next: Re: AppImages for EPICS base Pete Jemian via Tech-talk
Prev: Re: AppImages for EPICS base Pete Jemian via Tech-talk
Next: RE: Help with Blackfly FLIR/PointGrey Camera Mark L Rivers via Tech-talk
