Subject: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 30 Nov 2021 01:32:52 +0000
Hey All,
I am trying to make sure I understand how the CA Gateway networking setup works for running all pieces on the same PC(VM).  Below is my ENV variables list that I setup, I am just using the basic access list and pv list examples (although I did have a question about the access/pvlist)
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
export EPICS_CA_MAX_ARRAY_BYTES=800000
export EPICS_CAS_INTF_ADDR_LIST=localhost
export EPICS_CA_SERVER_PORT=5064
export EPICS_CAS_SERVER_PORT=5065
My understanding is that the CAS port is listening for requests from a client (in this case Phoebus).  I also am running Ralphs script to handle multiple IOCs on the same PC so UDP packets sent to 5064 are being echoed out on all ports (I think I need to block whichever port the CAS Server Port in this NAT Rule to stop looping).  Below is how I think the setup is supposed to work but I am unsure as I havnt been successful yet.
Phoebus PV UDP Request,NAT UDP Echoing Rule
5064 -> Broadcast
(Block 5068)
,IOC 1
Dynamic Port
,IOC 2
Dynamic Port
,IOC N
Dynamic Port
,Server 5068,Client 5064,PC
Access/PV List files question:
I am using the example files and for the access file the DEFAULT is where all requests go that aren’t listed as UAG or HAG?
ASG(DEFAULT) {
   RULE(1,READ)
For the Pvlist, the first 3 regex is this covering any PV name basically?  Does the next regex like Beam:.* then subset out from All to only Allowing the Beam 1 user to access these particular ones?
EVALUATION ORDER ALLOW, DENY
[0-9].*          ALLOW
[a-z].*          ALLOW
[A-Z].*          ALLOW
Beam:.*          ALLOW Beam 1
PS.*             ALLOW PowerSupply 1
gateway:.*Flag   ALLOW GatewayAdmin
test.*           DENY
ps\([0-9]\)      ALIAS PSCurrent\1.ai PowerSupply 1
Attachment: image001.emz
Description: image001.emz
PNG image
Attachment: image003.emz
Description: image003.emz
Attachment: image004.emz
Description: image004.emz
Attachment: image005.emz
Description: image005.emz
Attachment: image006.emz
Description: image006.emz
PNG image
PNG image
Attachment: image009.emz
Description: image009.emz
Attachment: image010.emz
Description: image010.emz
PNG image
PNG image
PNG image
PNG image
PNG image
Attachment: image016.emz
Description: image016.emz
RE: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
Prev: RE: CSS (Eclipse and Phoebus) super slow on a server with multiple users Jokinen Antti (F4E) via Tech-talk
Next: Re: MVME3100 boot failure at "Trying to find CSR on VME" Michael Davidsaver via Tech-talk
Prev: Re: MVME3100 boot failure at "Trying to find CSR on VME" Pete Jemian via Tech-talk
Next: RE: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
