On Dec 1, 2021, at 7:20 PM, Peter Linardakis <
[email protected]> wrote:
Thank
you all for the input. I've been trying different combinations without much success. There are other cards in the crate but the behaviour is the same whether there are none, some or all cards inserted. We have other similarly configured crates and the DIP
switch settings match. Since three MVME3100 units display the same behaviour in that crate, but get past that boot stage in another crate/backplane, the only thing I can think of is that we may have damaged the backplane? Does an MVME3100 theoretically even
need a backplane to get past that boot stage?
That depends what the software is doing when it boots. In the case of RTEMS it looks like the BSP code that Michael pointed to on GitHub first tries to run a VME bus cycle with the CSR address modifier, then it will look for its own CRG register area on
the bus and probe that. In both cases I’m pretty sure the read cycle must be completed properly for the probe test to return, and your symptoms imply that it isn’t being.
There are 2 ways for a VME bus cycle to finish — if another card accepts the cycle it will respond by pulling the DTACK* line low. If nothing on the bus responds there should be a timer on the system controller board (in slot 0, usually the TSI-148 chip
on your CPU board) which will pull the BERR* line after some (programmable) timeout period.
Michael was wondering if there might be an issue with using an MVME3100 board on a backplane that is older than the VME-64X standard; I can confirm there should be no issues there, the development system in my office pre-dates that and I have never had
any problems running any VME-64X CPUs in it.
I think you may have a damaged backplane, although it’s also possible that someone added or removed jumpers or termination resistors which have left it in an unusable state — if you have a working system from the same manufacturer you could do a detailed
comparison to see what if anything is different about the two backplanes. It might be worth checking the power supply too, ensuring that all the voltages are still within spec — PSUs are usually the first pieces of electronics that fail on older equipment,
and it’s possible that this might affect the ability to run bus cycles on it.
- Andrew
-----Original
Message-----
Michael Davidsaver <[email protected]>
Sent:
Wednesday, 1 December 2021 3:09 AM
To:
Johnson, Andrew N. <[email protected]>;
Peter Linardakis <[email protected]>
Cc:
EPICS tech-talk <[email protected]>
Subject:
Re: MVME3100 boot failure at "Trying to find CSR on VME"
On
11/30/21 7:05 AM, Johnson, Andrew N. wrote:
On Nov 29, 2021, at 8:33 PM, Michael Davidsaver via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
On 11/28/21 9:12 PM, Peter Linardakis via Tech-talk wrote:
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
Does anyone have any ideas why a certain backplane will cause this?
CSR in this context refers to the CSR address space, which is a VME64
extension using the geographic address pins, which won't be present
in an older VME32 crate.
Still, this error shouldn't be fatal as the TSI148 driver should fall
back and print "Trying to find CRG on VME...".
https://aus01.safelinks.protection.outlook.com/?url="">
hub.com%2FRTEMS%2Frtems%2Fblob%2Fe945e3fc4d6a6a74789c9a348120ec7d06e1
9231%2Fbsps%2Fpowerpc%2Fshared%2Fvme%2FvmeTsi148.c%23L1715&data="" class="">
4%7C01%7Cpeter.linardakis%40anu.edu.au%7Cc0b7a358faa84bbe6a1c08d9b41b
c1c7%7Ce37d725cab5c46249ae5f0533e486437%7C0%7C0%7C637738854022347930%
7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6I
k1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=BkfYhyq83jjPQ2dBF9F5fiKLGIzOub
xxbAtOSuIu3jk%3D&reserved=0
<https://aus01.safelinks.protection.outlook.com/?url="">
thub.com%2FRTEMS%2Frtems%2Fblob%2Fe945e3fc4d6a6a74789c9a348120ec7d06e
19231%2Fbsps%2Fpowerpc%2Fshared%2Fvme%2FvmeTsi148.c%23L1715&data="" class="">
04%7C01%7Cpeter.linardakis%40anu.edu.au%7Cc0b7a358faa84bbe6a1c08d9b41
bc1c7%7Ce37d725cab5c46249ae5f0533e486437%7C0%7C0%7C637738854022347930
%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6
Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=BkfYhyq83jjPQ2dBF9F5fiKLGIzOu
bxxbAtOSuIu3jk%3D&reserved=0>
Since the CPU on this backplane apparently hangs before printing that "CRG" message, my guess is that either the VME system controller isn't generating a BERR signal if/when nothing responds to the I/O cycle after some suitable timeout interval (I assume from
the probe operation in the call at line 1717), or maybe that the backplane has a problem with its BERR* signal line not working properly (is it terminated properly?). If the CPU doesn't see a falling edge on either the BERR or DTACK signal it will hang waiting
for a data from the read cycle which never completes. If this CPU *is* the VME system controller the code should have enabled a cycle timeout, but going back to what Heinz was talking about you need to make sure that the SCON is properly enabled and that the
CPU is in slot 0.
For
what little it is worth, I once successfully setup a mvme3100 with RTEMS (4.9.x) in an old (antique?) VME32 crate. However, that was 10 years ago and I don't now recall what all I had to do.
wrt.
SCON there are a pair of DIP switches in the S4 bank which can be set to force a mvme3100 to be SCON.
see
sections 1.4.2 and 1.4.3.
