Hi Will,
- Does the error happen when only a single camera is running at once, or only when multiple cameras are running at the same time?
- If the latter, then are they running in one IOC or 3 IOCs, and what is the total amount of Ethernet bandwidth being used?
Are all 3 cameras running the same firmware version?
Have you tried to reproduce the problem using the FLIR SpinView program?
I am using a FLIR blackfly_50A2M_CS camera with Area Detector version 3.1 EPICS R7.0.4.1 on Ubuntu 20.04.
I can acquire images with one camera, with 2 other cameras with identical settings I can acquire images for some amount of time and then I get a bunch of errors in iocsh all of the following pattern:
“exception Spinnaker: Error reading from device [SN:Unknown], at register address: F0F8000C. Please try reconnecting the device. [-1010]”
Given that I see this problem with 2 cameras and not one I think it’s a problem with the cameras. Before I contact FLIR I wanted to see if anybody else here had seen a similar problem?
Thanks
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
- RE: FLIR Camera with AD Spinnaker losses ID Smith, William via Tech-talk
- FLIR Camera with AD Spinnaker losses ID Smith, William via Tech-talk
Re: Trying to use elauncher: _main_ thread failed Hu, Yong via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
