Subject: RE: FLIR Camera with AD Spinnaker losses ID
From: "Smith, William via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Dec 2021 12:09:32 +0000
Hi Mark,
I conducted a few more tests to answer your questions:
  1. The error happens when only one camera is acquiring, as well as when all are acquiring
  2. They are running in separate IOC’s.
In total I have only 100MBs of bandwidth available on the network. I am using a dedicated NIC on my server for the cameras, this peaks at about 25MBs during acquisition with the one camera.
  1. All three cameras are running the same firmware version
  2. I have tried to repeat the error with the SpinView program and I can. I think this last point probably shows it’s a camera problem, I will contact FLIR
Will
Sent: Tuesday, December 7, 2021 2:35 PM
To: [email protected]; Smith, William <[email protected]>
Subject: Re: FLIR Camera with AD Spinnaker losses ID
Hi Will,
  • Does the error happen when only a single camera is running at once, or only when multiple cameras are running at the same time?
  • If the latter, then are they running in one IOC or 3 IOCs, and what is the total amount of Ethernet bandwidth being used?
  • Are all 3 cameras running the same firmware version?
  • Have you tried to reproduce the problem using the FLIR SpinView program?
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Tuesday, December 7, 2021 6:41 AM
To: [email protected] <[email protected]>
Subject: FLIR Camera with AD Spinnaker losses ID
I am using a FLIR blackfly_50A2M_CS camera with Area Detector version 3.1 EPICS R7.0.4.1 on Ubuntu 20.04.
I can acquire images with one camera, with 2 other cameras with identical settings I can acquire images for some amount of time and then I get a bunch of errors in iocsh all of the following pattern:
“exception Spinnaker: Error reading from device [SN:Unknown], at register address: F0F8000C. Please try reconnecting the device. [-1010]”
Given that I see this problem with 2 cameras and not one I think it’s a problem with the cameras. Before I contact FLIR I wanted to see if anybody else here had seen a similar problem?
Thanks
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
FLIR Camera with AD Spinnaker losses ID Smith, William via Tech-talk
Re: FLIR Camera with AD Spinnaker losses ID Mark Rivers via Tech-talk
Prev: Re: PyDevice and an IOC Florian Feldbauer via Tech-talk
Next: Re: PyDevice and an IOC Josh Fiddler via Tech-talk
Prev: Re: FLIR Camera with AD Spinnaker losses ID Mark Rivers via Tech-talk
Next: How to put the contents of a file in a waveform record Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
