Ah, I hadn't realized it was davidsaver who'd made this one too. I knew he'd developed pydevsup, which I use elsewhere.
So I did declare the bo correctly, but realized I was still getting the error even when I removed my .db file with the launcher bo. It was as if it was looking for @python ... or info(cmd, "...") for all my non-launcher bo's too. Turns out it was the order in which I added lines to my src/Makefile that was the issue. <myioc>_DBD+= had to be grouped with similar lines. It now seems to be working.
Thank you for the link Yong! I couldn't find anything when I searched for more information. From: Hu, Yong <[email protected]>
Sent: Tuesday, December 7, 2021 11:46:06 AM To: Crisp, Daniel; [email protected] Cc: Barofsky, Daniel Subject: Re: Trying to use elauncher: _main_ thread failed [EXTERNAL] This email originated from outside of FRIB
That program was developed by Michael Davidsaver at NSLS-2 many years ago. How do you load you *.db file in your st.cmd? You need a ‘bo’ record similar to this: https://github.com/NSLS-II/elauncher/blob/main/elauncherApp/Db/elauncher.db
Yong From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]> I don't see much documentation about what we call 'elauncher' here, so I'm thinking it might be something site specific? In any case, It's what we use to add PVs that trigger python scripts to our IOCs. I've attached
the source code we add to our src/ folder. We also have an elaunchSupport.dbd file that simply contains two lines 'device(bo, INST_IO, devLauncher, "Launcher")'' and 'variable(launcherVerbose, int)'. I'm getting an error when attempting to start the IOC, and I'm wondering if someone here could enlighten me as to the problem: ``` A call to 'assert(prec->out.type == INST_IO)' by thread '_main_' failed in ../launcher.c line 80. Dumping a stack trace of thread '_main_': [ 0x7f95a3285283]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsStackTrace+0x73) [ 0x7f95a327e7af]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsAssert+0x4f) [ 0x5604d5f29b2f]: ../../bin/linux-x86_64/hlc_s800(add_record+0x4f) [ 0x7f95a3309ea7]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(coreRelease+0x837) [ 0x7f95a330a10a]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocBuild+0x1a) [ 0x7f95a330a299]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocInit+0x9) [ 0x7f95a32700fb]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(gphDump+0x125b) [ 0x5604d5f1fea2]: ../../bin/linux-x86_64/hlc_s800(main+0x12) [ 0x7f95a309e09b]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [ 0x5604d5f1fefa]: ../../bin/linux-x86_64/hlc_s800(_start+0x2a) EPICS Release EPICS R3.15.8-2+0~20201111173402.6+debian10~1.gbp133abb. Local time is 2021-12-04 14:33:29.880008830 EST Please E-mail this message to the author or to [email protected] epicsThreadSuspendSelf() ```
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
