Subject: Re: ADPilatus writing cbf strangeness
From: John Dobbins via Tech-talk <[email protected]>
Cc: Jacob Ruff <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Dec 2021 16:29:24 +0000
Mark,
Yes, the filepath for the IOC is PPU ramdisk. I will investigate per your suggestion.
John
Sent: Friday, December 10, 2021 11:22 AM
To: John Dobbins <[email protected]>
Cc: Jacob Ruff <[email protected]>; [email protected] <[email protected]>
Subject: RE: ADPilatus writing cbf strangeness
Hi John,
What is the FilePath you are using for ADPilatus?  Is it reading from the PPU ramdisk?
I suggest you run camonitor on one of the PVs that updates each time ADPilatus reads a CBF file and does NDArray callbacks.  Is it gradually falling behind the detector so that after N images the allowed timeout has been reached?  Have you looked at “top” to see if the ADPilatus task is CPU bound, perhaps because the time to read the CBF files is longer than the time between when they are created?
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Friday, December 10, 2021 10:15 AM
To: [email protected]
Subject: ADPilatus writing cbf strangeness
All,
I am hoping you can help me understand what is happening when I try to write cbf files from a PILATUS 6M.
ADCore 3.9 ADPilatus Driver 2.9
If I write tiff files everything seems fine.
When I write cbf files it works for slow acquisition rate, say 1 Hz.
At ~ AcquirePeriod = 0.35, ExposureTime =0.09, NumImages =20
internal trigger
PIL10:cam1:StatusMessage_RBV reports a series of messages like
"Reading Image File ....."
But after ~ 13 or 14 images I get a message
"Timeout waiting for file to be created"
All 20 images appear to be written normally to disk.
I tried changing PIL10:cam1:ImageFileTmot from 5 to 10 to 20 but this doesn't seem to have any effect other than delaying the appearance of the error message.
Note our set-up is:
DCU runs camserver, collects images from detector which it writes to local ramdisk
PPU hosts IOC which communicates with camserver
Furka copies images from DCU ramdisk to PPU rammdisk, Grimsel copies images from PPU ramdisk to final destination (a network location)
Any guidance would be appreciated.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
RE: ADPilatus writing cbf strangeness Mark Rivers via Tech-talk
Re: ADPilatus writing cbf strangeness John Dobbins via Tech-talk
Prev: RE: ADPilatus writing cbf strangeness Mark Rivers via Tech-talk
Next: RE: ADPilatus writing cbf strangeness Mark Rivers via Tech-talk
