Subject: Re: [EXTERNAL] CSS Toggle button advice
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Tech-talk <[email protected]>, Donny Domagoj Cosic <[email protected]>
Date: Mon, 13 Dec 2021 14:08:40 +0000
The toggle button interfaces to a boolean PV, which is basically an enum PV with two states.
Create an mbbo record on the IOC, either add it to your existing IOC, or to a new soft IOC, which has two states and uses 000000 for the zero value, 111111 for the one value.
-Kay
From: Tech-talk <[email protected]> on behalf of Donny Domagoj Cosic via Tech-talk <[email protected]>
Sent: Monday, December 13, 2021 9:03 AM
Subject: [EXTERNAL] CSS Toggle button advice
Hello,
I would like to create a toggle button that sends 111111 when pressed
and 000000 when depressed to a PV that in turned sends a command to a
device using StreamDevice. I am not sure how to do this because the only
toggle type widget available in CSS is a boolean button which can send 1
or 0. Could I do this using a padding in the device proto file, but how
to make the padding depended on the input?
Any advice how this can be achieved would be greatly appreciated.
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Re: [EXTERNAL] CSS Toggle button advice Donny Domagoj Cosic via Tech-talk
Prev: CSS Toggle button advice Donny Domagoj Cosic via Tech-talk
Next: RE: CSS (Eclipse and Phoebus) super slow on a server with multiple users Jokinen Antti (F4E) via Tech-talk
Next: Re: [EXTERNAL] CSS Toggle button advice Donny Domagoj Cosic via Tech-talk
