Hi Kay,
Thank you very much for your advice. It worked like a charm!
Donny Domagoj Cosic
Laboratory for Ion Beam Interactions
Ruđer Bošković Institute
Bijenička cesta 54 | HR-10 000 Zagreb | CROATIA
T: +385 1 4561 041 | @: [email protected] | www.irb.hr
Dana 13.12.2021 15:08, Kasemir, Kay je napisao(la):
The toggle button interfaces to a boolean PV, which is basically an
enum PV with two states.
Create an mbbo record on the IOC, either add it to your existing IOC,
or to a new soft IOC, which has two states and uses 000000 for the
zero value, 111111 for the one value.
-Kay
FROM: Tech-talk <[email protected]> on behalf of Donny
Domagoj Cosic via Tech-talk <[email protected]>
SENT: Monday, December 13, 2021 9:03 AM
TO: Tech-talk <[email protected]>
SUBJECT: [EXTERNAL] CSS Toggle button advice
Hello,
I would like to create a toggle button that sends 111111 when pressed
and 000000 when depressed to a PV that in turned sends a command to a
device using StreamDevice. I am not sure how to do this because the
only
toggle type widget available in CSS is a boolean button which can
send 1
or 0. Could I do this using a padding in the device proto file, but
how
to make the padding depended on the input?
Any advice how this can be achieved would be greatly appreciated.
Donny Domagoj Cosic
- CSS Toggle button advice Donny Domagoj Cosic via Tech-talk
- Re: [EXTERNAL] CSS Toggle button advice Kasemir, Kay via Tech-talk
Re: Log4Shell approaches Jörn Dreyer via Tech-talk
Photonic Science X-ray FDS camera Sintschuk, Michael via Tech-talk
<2021>
2025
2026
Log4Shell approaches Shankar, Murali via Tech-talk
<2021>
2025
2026
