Subject: RE: arv-tools not detecting USB3 camera
To: "Gofron, Kazimierz" <[email protected]>, "Engbretson, Mark S." <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Mon, 13 Dec 2021 22:09:48 +0000
Hi Kaz,
I am running Centos8, which is basically the same as RHEL8.  I have the same libusb-devel and libusbx-devel packages installed that you do, and no package with a name lib libusb-1.0.
[epics@viper meson-logs]$ yum list installed | grep libusb
libusb.x86_64                                      1:0.1.5-12.el8                                    @BaseOS
libusb-devel.x86_64                                1:0.1.5-12.el8                                    @PowerTools
libusbmuxd.x86_64                                  1.0.10-9.el8                                      @AppStream
libusbx.x86_64                                     1.0.22-1.el8                                      @anaconda
libusbx-devel.x86_64                               1.0.22-1.el8                                      @BaseOS
But the meson build worked for me.  This is the relevant part of meson-build.txt:
Determining dependency 'libusb-1.0' with pkg-config executable '/usr/bin/pkg-config'
Called `/usr/bin/pkg-config --modversion libusb-1.0` -> 0
1.0.22
Called `/usr/bin/pkg-config --cflags libusb-1.0` -> 0
-I/usr/include/libusb-1.0
Called `/usr/bin/pkg-config libusb-1.0 --libs` -> 0
-L/usr/lib64 -lusb-1.0
-lusb-1.0
Dependency libusb-1.0 found: YES 1.0.22
Did you try rebuilding aravis?
From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Monday, December 13, 2021 3:59 PM
To: Engbretson, Mark S. <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>
Subject: Re: arv-tools not detecting USB3 camera
Hi Mark,
I am not sure if USB3 dependency is compiled in. Frankly, I am not sure how to check it. I looked at meson-log.txt, and it confirms it by looking for  'libusb-1.0' package, which exists on debian, but not on RedHat (to my knowledge). I might be wrong here.
In meson-log.txt
"Preliminary CMake check failed. Aborting.
Run-time dependency libusb-1.0 found: NO (tried pkgconfig and cmake)"
"Called `/usr/bin/cmake --trace-expand --trace-format=json-v1 --no-warn-unused-cli --trace-redirect=cmake_trace.txt .` in /epics/src/modules/aravis/build/meson-private/cmake_libusb-1.0 -> 0
  -- Module search paths:    ['/', '/opt', '/usr', '/usr/local']
  -- CMake root:             /usr/share/cmake
  -- CMake architectures:    []
  -- CMake lib search paths: ['lib', 'lib32', 'lib64', 'libx32', 'share']
That indicates that it is looking for libusb-1.0 package, which to my knowledge does not exist on RedHat.
So maybe USB3 support is not compiled in, because libusb-1.0 does not exist (to my knowledge) on redhat.
Kaz
Sent: Monday, December 13, 2021 1:59 PM
To: Gofron, Kazimierz <[email protected]>
Is the version of aravis that you are using built with the USB3 support enabled?
Sent: Monday, December 13, 2021 12:56 PM
Hi Mark,
Good point, and I did not install aravis udev rules yet.
However, when arv-tools is run as root, it does not detect the USB3 camera either.
[root@xf11id-m3 ~]# arv-tool-0.8 -d all
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.11.1 (192.168.11.255)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.69.24.152 (10.69.24.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.66.83.36 (10.66.83.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.122.1 (192.168.122.255)
[11:52:14.712]
🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:19:a3:18'
[11:52:14.712]
🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:1a:01:7e'
Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368 (192.168.11.11)
Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534 (192.168.11.12)
Something else is missing on RedHat...
Kaz
Sent: Monday, December 13, 2021 1:11 PM
Do you have the aravis udev rules installed so that non root accounts can actually see the usb3 hardware?
Sent: Monday, December 13, 2021 12:00 PM
To: [email protected]
Subject: arv-tools not detecting USB3 camera
I have a USB3 Grasshopper3 GS3-U3-51S5C camera that arv-tools-0.8 is not detecting.
The GS3-U3-51S5C supports USB3 Vision v1.0
OS: Redhat 8.4
{Aravis detects only my GigE cameras:}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8
{arv-tools with options does not list usb camera either}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8 -d all
[15:02:46.093] ?? interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
{The camera shows up in libusb and /dev/bus/usb, but is not found by arv-tool:}
kgofron@xf11id-m3:/epics/iocs/cam-aravis1$ lsusb
Bus 002 Device 003: ID 1e10:3300 Point Grey Research, Inc.
kgofron@xf11id-m3:/epics/iocs$ ls /dev/bus/usb/002/003
{USB camera is on bus 002 device 003}
Camera details:
kgofron@xf11id-m3:/dev/bus/usb/002$ usb-devices
T:  Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#=  3 Spd=5000 MxCh= 0
D:  Ver= 3.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS= 9 #Cfgs=  1
P:  Vendor=1e10 ProdID=3300 Rev=00.00
S:  Manufacturer=Point Grey Research
S:  Product=Grasshopper3 GS3-U3-51S5C
S:  SerialNumber=0123EF71
C:  #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=896mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=ef(misc ) Sub=05 Prot=00 Driver=(none)
I:  If#=0x1 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=01 Driver=(none)
I:  If#=0x2 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=02 Driver=(none)
USB support is installed:
libusb-devel.x86_64
Any suggestions about this problem?
Kazimierz Gofron
Re: arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
RE: arv-tools not detecting USB3 camera Engbretson, Mark S. via Tech-talk
Prev: Re: arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
Next: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
Next: Re: arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
