Subject: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
From: Kevin Peterson via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>, Mrinal Bera <[email protected]>
Date: Mon, 13 Dec 2021 16:26:31 -0600
The MAXv has internal filters on the limit lines that the MAXnet controller lacks:
  https://epics.anl.gov/tech-talk/2017/msg00243.php
If there is noise on the limit lines of a MAXnet axis, moves will stop prematurely. A significant amount of noise can make motors unusable from EPICS.
Kevin
On 12/8/21 08:18, Mark Rivers via Tech-talk wrote:
Hi Mrinal,
There is now a 10-axis version of the MAXnet, so you could use just 2 of them.  The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC.  Each is a separate asynPortDriver object with a different asyn port name.
If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution.  You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler. If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Prev: RE: arv-tools not detecting USB3 camera Mark Rivers via Tech-talk
Next: Re: [Ext] RE: ADEiger Stream stop zmq? Jesse Hopkins via Tech-talk
Prev: RE: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
Next: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
