Hi Mrinal,
There is now a 10-axis version of the MAXnet, so you could use just 2 of them. The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC. Each is a separate asynPortDriver object with a different
asyn port name.
If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution. You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler.
If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
While looking for 18 axis application, I came across the OMS SPI-MAXnet 8000 8-axis controller. For the 18 axis application, I would need 3 of such controllers. As the EPICS motor record support OMS-MAXnet controllers, would it be possible to configure all
the three controllers under a single soft-IOC, or do I need to run 3 separate soft-IOCs?
Best,
Mrinal
- Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
- Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
- Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Re: [EXTERNAL] PyDevice and an IOC Vodopivec, Klemen via Tech-talk
Re: [EXTERNAL] PyDevice and an IOC Ralph Lange via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
