Thanks, Kevin for the info! We have now decided to go ahead with OMS MAXv cards.
Mrinal
> On Dec 13, 2021, at 4:26 PM, Kevin Peterson <[email protected]> wrote:
> The MAXv has internal filters on the limit lines that the MAXnet controller lacks:
> https://epics.anl.gov/tech-talk/2017/msg00243.php
> If there is noise on the limit lines of a MAXnet axis, moves will stop prematurely. A significant amount of noise can make motors unusable from EPICS.
> Kevin
> On 12/8/21 08:18, Mark Rivers via Tech-talk wrote:
>> Hi Mrinal,
>> There is now a 10-axis version of the MAXnet, so you could use just 2 of them. The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC. Each is a separate asynPortDriver object with a different asyn port name.
>> If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution. You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler. If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
>> Mark
- Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
- Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mark Rivers via Tech-talk
- Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
Re: ADVimba memory leak ? John Dobbins via Tech-talk
Re: Log4Shell approaches Matt Clarke via Tech-talk
<2021>
2025
2026
AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
<2021>
2025
2026
