Subject: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Wed, 8 Dec 2021 16:54:22 +0000
Hello EPICS-community,
as the title of this thread says, I’m wondering if it is possible to dynamically select where an incoming frame is placed within the HDF5-Files structure. For example, while capturing frames in Stream-mode with the default HDF5-Files structure layout, all incoming frames are placed to:
entry -> instrument -> detector -> data
Now I want to load an individual hdf5-layout.xml with the additional location “flat”:
entry -> instrument -> detector -> flat
Is there a way that I can switch (via an EPICS-PV) the location where the next frame is stored, either “entry -> instrument -> detector -> data” or “entry -> instrument -> detector -> flat”, while the h5-files is still opened? Example scan with a total of 1000 frames, all should go into one h5-file:
  • h5-files is opened
  • the first 20 frames are placed to entry -> instrument -> detector -> flat
  • the next 960 frames are placed to entry -> instrument -> detector -> data
  • the last 20 frames are placed to entry -> instrument -> detector -> flat
  • h5-files is closed
In the AreaDetector user-guide there is the following section:
https://areadetector.github.io/master/ADCore/NDFileHDF5.html#selective-positional-placement-of-individual-frames
I switched on the Position mode and put Index N to 0 (or 1) and put Name N to “flat” but I get a Write error status. I think I don’t understand the handling of the dataset dimensions within the h5-file and don’t know if my frame-placement sequence is actually realizable. Can someone help?
Thanks!
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
[email protected]
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Pete Jemian via Tech-talk
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Mark Rivers via Tech-talk
Prev: Re: Need clarification on UDP Broadcasting to multiple IOCs on same PC Ralph Lange via Tech-talk
Next: Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Pete Jemian via Tech-talk
Prev: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
