Subject: |
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file |
Pete Jemian via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 8 Dec 2021 11:32:11 -0600 |
Take a look at this Jupyter notebook: https://github.com/BCDA-APS/bluesky_training/blob/4da2789cbbeaefa0ac95d0c449bba042a35cf831/.wip/images_darks_flats.ipynb
While it is marked as *work-in-progress*, it might point you in a forward direction.
HTH,
Pete
On 12/8/2021 10:54 AM, Sintschuk, Michael via Tech-talk wrote:
Hello EPICS-community,
as the title of this thread says, I’m wondering if it is possible to dynamically select where an incoming frame is placed within the HDF5-Files structure. For example, while capturing frames in Stream-mode with the default HDF5-Files structure layout, all incoming frames are placed to:
entry -> instrument -> detector -> data
Now I want to load an individual hdf5-layout.xml with the additional location “flat”:
entry -> instrument -> detector -> flat
Is there a way that I can switch (via an EPICS-PV) the location where the next frame is stored, either “entry -> instrument -> detector -> data” or “entry -> instrument -> detector -> flat”, while the h5-files is still opened? Example scan with a total of 1000 frames, all should go into one h5-file:
* h5-files is opened
* the first 20 frames are placed to entry -> instrument -> detector -> flat
* the next 960 frames are placed to entry -> instrument -> detector -> data
* the last 20 frames are placed to entry -> instrument -> detector -> flat
* h5-files is closed
In the AreaDetector user-guide there is the following section:
https://areadetector.github.io/master/ADCore/NDFileHDF5.html#selective-positional-placement-of-individual-frames <https://areadetector.github.io/master/ADCore/NDFileHDF5.html#selective-positional-placement-of-individual-frames>
I switched on the Position mode and put Index N to 0 (or 1) and put Name N to “flat” but I get a Write error status. I think I don’t understand the handling of the dataset dimensions within the h5-file and don’t know if my frame-placement sequence is actually realizable. Can someone help?
Thanks!
Michael
Michael Sintschuk
*Bundesanstalt für Materialforschung und –prüfung (BAM)*
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected] <mailto:[email protected]>
Pete R. Jemian, Ph.D. <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source, Argonne National Laboratory
Argonne, IL 60439 630 - 252 - 3189
Education is the one thing for which people
are willing to pay yet not receive.
- AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Sintschuk, Michael via Tech-talk
Re: AreaDetector NDFileHDF5 dynamic frame-placement within an opened H5-file Mark Rivers via Tech-talk
<2021>
2025
2026
<2021>
2025
2026
