Subject: Re: Re: Ask for help about compiling ADAravis on openEuler 20.03 LTS
To: "Mark Rivers" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 20 Dec 2021 18:51:03 +0800
Dear Mark:
    Thank you for the instructions, with WITH_GRAPHICSMAGICK = NO, I succeed the compiling process and summarized in the following link:
https://blog.csdn.net/weixin_43767046/article/details/122042837
Thanks
yours
Lu Ping
Date: 2021-12-19 22:25
Subject: Re: Ask for help about compiling ADAravis on openEuler 20.03 LTS
Hi Lu Ping,
I can tell from your link command output that you are not using the version of GraphicsMagick the comes with ADSupport, you are a version elsewhere on your system. It seems like your CONFIG_SITE.local file probably has:
WITH_GRAPHICSMAGICK     = YES
GRAPHICSMAGICK_EXTERNAL = YES
If you don't actually need GraphicsMagick for your application you can just set WITH_GRAPHICSMAGICK=NO.  If you want to use GraphicsMagick then you could try
GRAPHICSMAGICK_EXTERNAL = NO
From: Tech-talk <[email protected]> on behalf of lup--- via Tech-talk <[email protected]>
Sent: Sunday, December 19, 2021 4:07 AM
To: tech-talk <[email protected]>
Subject: Ask for help about compiling ADAravis on openEuler 20.03 LTS
Hi All:
I have complied ADAravis on Centos7 and summarized the processing:
I want to compile it on openEuler,the last step, I met the following problem:
/usr/bin/g++ -o ADAravisApp  -L/opt/epics/support/areaDetector-R3-11/ADAravis/lib/linux-x86_64 -L/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC/lib/linux-x86_64 -L/opt/epics/base/lib/linux-x86_64 -L/opt/epics/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -L/opt/epics/support/areaDetector-R3-11/ADGenICam/lib/linux-x86_64 -L/opt/epics/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -L/opt/epics/support/asyn-R4-42/lib/linux-x86_64 -L/opt/epics/support/autosave-R5-10-2/lib/linux-x86_64 -L/opt/epics/support/busy-R1-7-3/lib/linux-x86_64 -L/opt/epics/support/calc-R3-7-4/lib/linux-x86_64 -L/opt/epics/support/iocStats-3-1-16/lib/linux-x86_64 -L/opt/epics/support/seq-2-2-9/lib/linux-x86_64 -L/opt/epics/support/sscan-R2-11-5/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/areaDetector-R3-11/ADAravis/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC/lib/linux-x86_64 -Wl,-rpath,/opt/epics/base/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/areaDetector-R3-11/ADGenICam/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/asyn-R4-42/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/autosave-R5-10-2/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/busy-R1-7-3/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/calc-R3-7-4/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/iocStats-3-1-16/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/seq-2-2-9/lib/linux-x86_64 -Wl,-rpath,/opt/epics/support/sscan-R2-11-5/lib/linux-x86_64 -ltirpc     ADAravisApp_registerRecordDeviceDriver.o ADAravisAppMain.o   -lADAravis -lADGenICam -lNDPlugin -lADBase -lqsrv -lntndArrayConverter -lnt -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -lnetCDF -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -lasyn -lautosave -lbusy -lcalc -ldevIocStats -lsscan -lseq -lpv -ldbRecStd -ldbCore -lca -lCom  -laravis-0.8 -lgio-2.0 -lgobject-2.0 -lgthread-2.0 -lglib-2.0 -lusb-1.0 -lGraphicsMagick++ -lGraphicsMagick -lX11 -lXext
/usr/bin/ld: /opt/epics/support/areaDetector-R3-11/ADCore/lib/linux-x86_64/libNDPlugin.so: undefined reference to `Magick::GmInitializeMagick(char const*)'
collect2: error: ld returned 1 exit status
make[5]: *** [/opt/epics/base/configure/RULES_BUILD:231: ADAravisApp] Error 1
make[5]: Leaving directory '/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC/aravisApp/src/O.linux-x86_64'
make[4]: *** [/opt/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[4]: Leaving directory '/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC/aravisApp/src'
make[3]: *** [/opt/epics/base/configure/RULES_DIRS:85: src.install] Error 2
make[3]: Leaving directory '/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC/aravisApp'
make[2]: *** [/opt/epics/base/configure/RULES_DIRS:85: aravisApp.install] Error 2
make[2]: Leaving directory '/opt/epics/support/areaDetector-R3-11/ADAravis/iocs/aravisIOC'
make[1]: *** [/opt/epics/base/configure/RULES_DIRS:85: aravisIOC.install] Error 2
make[1]: Leaving directory '/opt/epics/support/areaDetector-R3-11/ADAravis/iocs'
make: *** [/opt/epics/base/configure/RULES_DIRS:85: iocs.install] Error 2
[beam@localhost ADAravis]$
I don't know how to solve it, ask for help, Thanks.
The first time sent message in the mailist, sorry if disturb.
yours
Lu Ping
Ask for help about compiling ADAravis on openEuler 20.03 LTS lup--- via Tech-talk
Re: Ask for help about compiling ADAravis on openEuler 20.03 LTS Mark Rivers via Tech-talk
Prev: Re: Ask for help about compiling ADAravis on openEuler 20.03 LTS Mark Rivers via Tech-talk
Next: Canadian Light Source - Job Posting Riley Stefaniuk via Tech-talk
