Subject: Re: Reliability of caput
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 20 Dec 2021 21:15:57 -0800
On 12/20/21 4:22 PM, Wang, Andrew via Tech-talk wrote:
> All,
> Quick question.
> Suppose I have two analog input records called “A” and “B” on which I would like to do caput. If I have a bash script containing the following code:
> caput A 100
> caput B 200
> Will that give sufficient time for caput to respond? Or should there ideally be a “delay” between each caput. The reason why I ask is because within the sequencer, we do something similar, but with pvPut, and sometimes we see that “B” does not get updated with a new value.
By default, ordering w/ CA (and PVA) is not strict.  As you have found
in the situation you describe, it is possible for the effects of B to
precede A.  With CA this can be made stricter with the ca_put_callback
operation.
> caput -c A 100
> caput -c B 200
Adding '-c' will cause caput to wait for the server/IOC to confirm that
the PUT has been completely processed before exiting.  (note also '-w'
for a timeout on this wait)
It's been awhile since I did this in the sequencer.  As I read it, passing
ASYNC or SYNC to pvPut() has the same effect as '-c'.  The difference
between these two modifiers is in how your sequencer program will need to
be adjusted to wait for the PUT operation(s) to complete.
cf. pvPut(), pvPutComplete(), pvPutCancel(), and the pvArray*() variants.
https://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html?highlight=pvput#pvput
Reliability of caput Wang, Andrew via Tech-talk
Prev: Re: Reliability of caput J. Lewis Muir via Tech-talk
Next: Multiple IOCs on a remote server Randall Cayford via Tech-talk
