Pete,
Which version of the motor record is being used? I've seen unexpected
motion problems with ancient versions of the motor record, but they
involved stopping a motor while it was in SET mode, not restoring
autosaved positions.
A new motor-record field, RSTM, is available in the master branch of the
motor module, which gives users more control over how autosaved
positions are restored:
https://github.com/epics-modules/motor/pull/160
Kevin
On 1/6/22 15:13, Siddons, David via Tech-talk wrote:
I would like to suggest an addition to the motor record logic (or
save-restore, not sure which). I have been bitten several times by
having a set of motors under save-restore and having a restart provoke a
runaway. The sequence goes like this:
motor system running fine, save-restore operating.
IOC is stopped.
Motors are powered down.
motors powered up, causing their internal position registers to be set
to zero.
IOC re-started, save restore writes previous positions into motor
driver, causing them to move to that position, and havoc!
My proposed change would cause someone (motor, save-restore) to notice
that the hardware and software disagree, and ask the User how they want
to resolve this dilemma. Those of you old enough to remember Spec know
that this is exactly how Spec behaved on startup. If the User decides
that the software is right, then the new positions should be entered in
the SET=1 mode. If she decides that the hardware is right, then that
value should be entered in the same way. It isn't enough to just take
the hardware value as right, since it is quite liable to be wrong, as
described above, although that would prevent runaways.
In my case, the problem was compounded by the fact that the STOP command
did not work! But that is the subject of another discussion.
Pete.
- Re: motor record startup Siddons, David via Tech-talk
- motor record startup Siddons, David via Tech-talk
phoebus: table of multiple pv's Pierrick M Hanlet via Tech-talk
<2022>
2025
2026
RE: motor record startup Mark Rivers via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
