1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: motor record startup
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Mooney, Tim M." <[email protected]>, "Peterson, Kevin M." <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 7 Jan 2022 21:02:12 +0000
Hi Tim,
   No, this is all within the IOC st.cmd. Not sure what's going on yet. Let me dig a while.
Pete.
Sent: Friday, January 7, 2022 3:57 PM
To: Peterson, Kevin M. <[email protected]>; EPICS Tech Talk <[email protected]>; Siddons, David <[email protected]>
Hi Pete,
Are you by any chance doing a manual restore after iocInit returns?  If so, autosave uses channel access (as opposed to static database access) for manual restores.  This would cause motors to move if values are restored to, say, VAL fields.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Friday, January 7, 2022 2:31 PM
Hi Kevin,
   It seems likely that Mark is tight and my save-restore is incorrectly set up. When I get to the bottom of it I'll post the solution. Also, part of it may be the driver, but until I fix the s-r stuff I can't be sure. The motor record is motor-R7-2-1.
Pete.
Sent: Friday, January 7, 2022 3:15 PM
To: Siddons, David <[email protected]>; EPICS Tech Talk <[email protected]>
Pete,
Which version of the motor record is being used?  I've seen unexpected
motion problems with ancient versions of the motor record, but they
involved stopping a motor while it was in SET mode, not restoring
autosaved positions.
A new motor-record field, RSTM, is available in the master branch of the
motor module, which gives users more control over how autosaved
positions are restored:
   https://github.com/epics-modules/motor/pull/160
Kevin
On 1/6/22 15:13, Siddons, David via Tech-talk wrote:
> I would like to suggest an addition to the motor record logic (or
> save-restore, not sure which). I have been bitten several times by
> having a set of motors under save-restore and having a restart provoke a
> runaway. The sequence goes like this:
> motor system running fine, save-restore operating.
> IOC is stopped.
> Motors are powered down.
> motors powered up, causing their internal position registers to be set
> to zero.
> IOC re-started, save restore writes previous positions into motor
> driver, causing them to move to that position, and havoc!
> My proposed change would cause someone (motor, save-restore) to notice
> that the hardware and software disagree, and ask the User how they want
> to resolve this dilemma. Those of you old enough to remember Spec know
> that this is exactly how Spec behaved on startup. If the User decides
> that the software is right, then the new positions should be entered in
> the SET=1 mode. If she decides that the hardware is right, then that
> value should be entered in the same way. It isn't enough to just take
> the hardware value as right, since it is quite liable to be wrong, as
> described above, although that would prevent runaways.
> In my case, the problem was compounded by the fact that the STOP command
> did not work! But that is the subject of another discussion.
> Pete.
motor record startup Siddons, David via Tech-talk
Re: motor record startup Kevin Peterson via Tech-talk
Re: motor record startup Siddons, David via Tech-talk
Re: motor record startup Mooney, Tim M. via Tech-talk
Prev: Re: motor record startup Mooney, Tim M. via Tech-talk
Next: European XFEL job ad: Control Software Engineer (f/m/d) Steffen Hauf via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: phoebus: table of multiple pv's Pierrick M Hanlet via Tech-talk
