1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: EPICS Motor record for Anorad Servo Motor Controller
To: Mrinal Bera <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Wed, 12 Jan 2022 16:45:11 +0000
Hi Mrinal,
The first thing I would suggest is to ask if Jerry Swislow is willing to send you the code for the SPEC driver, perhaps under a non-disclosure agreement.  You could then use that to write an EPICS driver.  If that does not work you could capture the RS-232 communication between SPEC and the controller, and use that to reverse engineer the protocol.
However, it might be cheaper to just replace the controller with a new one that already has EPICS support.  What are the specifications of the motor you are driving with it?
From: Tech-talk <[email protected]> On Behalf Of Mrinal Bera via Tech-talk
Sent: Wednesday, January 12, 2022 10:19 AM
To: [email protected]
Subject: EPICS Motor record for Anorad Servo Motor Controller
Hello,
First of all new year Greetings to everyone!
Currently, I am looking into creating an EPICS MotorApp to control Anorad I-SERV-BR1 Servo Motor Controller (https://www.artisantg.com/PLC/89701-1/Rockwell-Anorad-I-SERV-BR1-Servo-Motor-Controller). We have been using this motor controller through SPEC for more than 10 years or so. The controller is connected directly to the computer running SPEC using RS-232 connection. As per the documentation of the controller, the only information available currently is that the controller shares the same versatile language as ACSPL. My question to the community is:
1) Did anybody develop a motorApp for this kind of controller?
2) Can we use any existing EPICS motorApp for this contollerr?
Look forward to get some help to start on this project.
Thanks and regards,
Mrinal
Mrinal Kanti Bera, PhD
NSF’s ChemMatCARS
University of Chicago
9700 S Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
EPICS Motor record for Anorad Servo Motor Controller Mrinal Bera via Tech-talk
Prev: EPICS Motor record for Anorad Servo Motor Controller Mrinal Bera via Tech-talk
Next: Re: fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) Francisco Ramos via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Sequencer - Compiling multiple source files together Manoussakis, Adamandios via Tech-talk
