1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Sequencer - Compiling multiple source files together
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 13 Jan 2022 23:54:09 +0000
Hi Andrew,
The example files helped a ton, got it to compile now.  Planning on messing with macroing within the sequencer as well, is the easiest way to just set some env variables in envPaths file that I load in the st.cmd?
Adam
Sent: Thursday, January 13, 2022 10:43 AM
To: Manoussakis, Adamandios <[email protected]>
Subject: Re: Sequencer - Compiling multiple source files together
Hi Adam,
The sequencer’s build rules run each .st file through the C Preprocessor (generating the .i file which you’ll see in the O.<arch> directory) before compiling the result to a .c file, so you can use #include statements to pull the sources of other files into the .st that you ask the build system to compile. The result must of course be syntactically correct and you’ll need to be careful to not re-use the same global variable names in different sequences, but you should be able to split up your existing large file quite easily using that.
The makeBaseApp example uses that to compile the sncProgram.st file, although that is to generate a stand-alone executable so the Makefile entries will look slightly different.
HTH,
- Andrew
On Jan 13, 2022, at 12:28 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Hey All,
Is it possible to have multiple .st files and compile them together similar to #include in C and compiling the multiple .c files?  I couldn’t find anything explicit in the documentation, only that I could add in the SRCS += *.st files in the Makefile but I think this only compiles each st file separately?  My Goal is to separate out the multiple sequencers that I have currently in a large .st file.
Adam
Complexity comes for free, simplicity you have to work for.
Re: Sequencer - Compiling multiple source files together Johnson, Andrew N. via Tech-talk
Sequencer - Compiling multiple source files together Manoussakis, Adamandios via Tech-talk
Prev: Re: Sequencer - Compiling multiple source files together Johnson, Andrew N. via Tech-talk
Next: Re: Sequencer - Compiling multiple source files together Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
