Change this line:
field (FLNK, "$(P):current1.PROC")
to:
field (FLNK, "$(P):current1.PROC CA")
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Randall Cayford via Tech-talk <tech-talk at aps.anl.gov>
Date: Friday, January 14, 2022 at 3:18 PM
To: Gofron, Kazimierz via Tech-talk <tech-talk at aps.anl.gov>
Subject: FLNK doesn't process
I have a periodic scanned PV which I occasionally set. However, when I set it, I can’t read the updated value until the periodic scan happens. I would like the PV value to update
as soon as it’s set. I thought that was what was supposed to happen with FLNK but it doesn’t seem to.
My db has:
record (ai, "$(P):current1")
field (DTYP, "stream")
field (INP, "@thorlab.proto getcurrentch(1) $(BUS)")
field (SCAN, "10 second")
record (ao, "$(P):setcurrent1")
field (OUT, "@thorlab.proto setcurrentch(1) $(BUS)")
field (SCAN, "Passive")
"caput setcurrent1 10" works but it takes whatever is left of the 10 second scan period before current1 changes.
“caput current1.PROC 1” immediately updates the value in current1.
I tried field (FLNK, "$(P):current1”) but that doesn’t process either.
What’s the trick for getting a periodic scan PV to process within a forward link? Or is there some other way I’m supposed to do this?
Thanks.
Randall
LBNL
- Re: FLNK doesn't process Randall Cayford via Tech-talk
- FLNK doesn't process Randall Cayford via Tech-talk
<2022>
<2022>
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
