1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: ADCore R3-12 released
Date: Fri, 21 Jan 2022 00:27:27 +0000
Folks,
areaDetector ADCore R3-12 is now available.  From the RELEASE.md
ADAutoSaveMenu.req
  • New file to be used with the configMenu utility in autosave. It saves all of the camera and plugin settings defined in iocBoot/iocXXX/auto_settings.req. This allows manually saving and loading different configurations for different setups with the same IOC. It also allows saving and then loading the settings when a camera is reset or restarted, without restarting the IOC.
ADPlugins OPI sub-screen.
  • Added a related display "Plugins/Other #2/AS configMenu" which allows manually saving and loading configurations that use ADAutoSaveMenu.req described above.
ntndArrayConverter
  • Added conversion from Posix time to EPICS time when copying NTNDArray to NDArray.
EXAMPLE_commonPlugins.cmd
  • Load configMenu.db.
  • Fixes to set_request_file_path to use the /db directory rather than the App/Db directory.
commonDriverMakefile
  • Added optional reccaster support module.
CCDMultiTrack.cpp
  • Corrected index error.
NDFileHDF5AttributeDataset.cpp
  • Removed unnecessary creation of 1x1 dimensions.
Prev: Re: mrfioc2-PCI device Configuration Michael Davidsaver via Tech-talk
Next: Re: SmarPod with EPICS Randall Cayford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: mrfioc2-PCI device Configuration gjzhai--- via Tech-talk
Next: RE: Edwards SCU-800 Bernardo Brotas de Carvalho via Tech-talk
