1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: mrfioc2-PCI device Configuration
To: "Michael Davidsaver" <[email protected]>
Date: Wed, 2 Mar 2022 09:17:02 +0800 (GMT+08:00)
Hi Michael,
Thank you and GAGET Alexis for your many suggestions and help. The mrfioc2 IOC is now loaded and running.
Lesley
mrmEvrSetupPCI("MTCAEVR","slot=10")
Notice: devPCIFindSpec() expect B:D.F in hex
Device MTCAEVR  5:0.0 slot=10
Using IRQ 162
Failed to open resource file for PCI device 0000:05:00.0: Permission denied
FWVersion 0x18100207
Found version 519
Found SFP EEPROM
Sequencer capability detected
mTCA: Out FP:4 FPUNIV:0 RB:16 IFP:32 GPIO:2
EVR FIFO task start
Enabling interrupts
dbLoadRecords("db/evr-mtca-300.db","SYS=TST, D=evr:1, EVR=MTCAEVR")
mrmEvgSetupPCI("EVG", "8:0.0")
Device EVG  8:0.0
Using IRQ 163
Failed to open resource file for PCI device 0000:08:00.0: Permission denied
FPGA version: 280e0207
mTCA-EVM-300 #Inputs FP:3 UV:16 RB:0
EVM automatically creating 'EVG:FCT', 'EVG:EVRD', and 'EVG:EVRU'
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Warning: Recommended minimum firmware 2 version is 207.6, found 207.0
Found SFP Strangeness 00000000
VME 64: Out FP:8 FPUNIV:0 RB:0 IFP:8 GPIO:0
EVR FIFO task start
PCI interrupt connected!
EVR FIFO task start
> -----原始邮件-----
> 发件人: "Michael Davidsaver" <[email protected]>
> 发送时间: 2022-03-01 00:56:08 (星期二)
> 收件人: [email protected]
> 抄送: "[email protected]" <[email protected]>
> 主题: Re: mrfioc2-PCI device Configuration
> On 2/28/22 05:27, [email protected] wrote:
> >> Some file permissions need to be changed.  The best way to handle this is with a udev rule.
> >>> cat << EOF > /etc/udev/rules.d/99-mrfioc2.rules
> >>> KERNEL=="uio*", ATTR{name}=="mrf-pci", GROUP="softioc", MODE="0660"
> >>> EOF
> >>> udevadm control --reload
> >> It is also be worth noting that DKMS packaging is now include (added by Michael Abbot @DLS)
> >> to make OS kernel updates more automatic.
> >> In any case, you will need to choose an appropriate GROUP name for your site.
> > After I followed the above, the following appeared:
> > mrmEvrSetupPCI("MTCAEVR","5:0.0")
> > Using IRQ 162
> > Found version 519
> > Found SFP EEPROM
> > EVR FIFO task start
> > Enabling interrupts
> > Why does the error message of Permission denied still appear?
> The underlying devlib2 PCI access library knows two ways to access a PCI
> BAR under Linux.  With /dev/uio* and with another special file deep down
> in /sys.  The are equivalent.  The second is (currently) tried first.
> The /sys method doesn't require an OS driver.  So it can be sufficient for
> simple devices, or for troubleshooting (or some other strange situations).
> > In addition, the geographic address of the EVM is 08:00.0, but the following error message appears:
> > mrmEvgSetupPCI("EVG", 8, 0, 0)
> > Error: invalid spec '8'
> > PCI Device not found
> The four argument form of mrmEvgSetupPCI(NAME, BUS, DEV, FUNC) is legacy.
> Back when I thought PCI addressing was always as simple as BUS:DEV.FUNC .
> I tried to keep it working, but you have encountered a pathological case
> with DEV==FUNC==0.
> https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evgMrmApp/src/evgInit.cpp#L371-L382
> I recommend switching to the newer two argument form.
> Although seeing "slot=" indicates that geographical addressing is available.
> I tend to prefer putting slot numbers in config files when possible.
> So
> could be replaced with
> The devPCIShow() IOCsh function should show any slot numbers.
> http://epics.sourceforge.net/devlib2/iocsh.html#iocshpci
> In my experience.  While PCI slot numbers don't always map to physical slots in
> an intuitive way, that mapping is at least as stable as B:D.F addressing.
> Typically only backplane bus segments provide slot numbering.  So slot numbers
> aren't effected by the addition or removal of a bus segment with a lower BUS
> number.
> Slot number still isn't 100%.  Things get weird when two bus segments provide
> overlapping slot number ranges.  eg. a cPCI CPU with on board PMC sockets as
> well as the backplane.
> >> -----原始邮件-----
> >> 发送时间: 2022-02-28 01:49:27 (星期一)
> >> 抄送: "GAGET Alexis" <[email protected]>, "[email protected]" <[email protected]>
> >> On 2/26/22 23:50, [email protected] wrote:
> >>> Failed to open resource file for PCI device 0000:09:00.0: Permission denied
> >>> Can neither mmap resource file nor uio file of PCI device 0000:09:00.0 BAR 0
> >>> PCI error: Failed to map BAR 0
> >> There is an example in the README
> >> https://github.com/epics-modules/mrfioc2/tree/master/mrmShared/linux
> >>> EOF
> >>> More information:
> >>> [opi@localhost dev]$ ll
> >>> crw-rw----.  1 root root    241,     0 Feb 27 10:39 uio0
> >>> crw-rw----.  1 root root    241,     1 Feb 27 10:39 uio1
> >>> crw-rw----.  1 root root    241,     2 Feb 27 10:39 uio2
> >>> [opi@localhost]$ sudo udevadm info -q path -n /dev/uio0
> >>> /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:01.0/0000:03:00.0/0000:04:00.0/0000:05:00.0/uio/uio0
> >>> [opi@localhost]$ sudo udevadm info -q path -n /dev/uio1
> >>> /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:01.0/0000:03:00.0/0000:04:03.0/0000:08:00.0/uio/uio1
> >>> [opi@localhost]$ sudo udevadm info -q path -n /dev/uio2
> >>> /devices/pci0000:00/0000:00:01.0/0000:01:00.0/0000:02:01.0/0000:03:00.0/0000:04:04.0/0000:09:00.0/uio/uio2
> >>>> -----原始邮件-----
> >>>> 发送时间: 2022-01-24 01:03:06 (星期一)
> >>>> On 1/23/22 01:15, [email protected] wrote:
> >>>>> Can't read private key
> >>>>>      DEPMOD  3.10.0-1160.42.2.el7.x86_64
> >>>>> [root@localhost mrmShared]# dmesg | grep mrf
> >>>>> [    1.338766] pci_mrfevr: loading out-of-tree module taints kernel.
> >>>>> [    1.339091] pci_mrfevr: module verification failed: signature and/or required key missing - tainting kernel
> >>>> I guess your (RHEL7) system has kernel module signing at least partially enabled?
> >>>> Personally, I have no experience with this feature.  So I can't advise you on how
> >>>> to sign locally built kernel modules.
> >>>>> [    1.340025] mrfevr:BAR0 start df200000 end df23ffff, mmap c3700000
> >>>>> [    1.340296] mrfevr:BAR0 start df000000 end df03ffff, mmap c3780000
> >>>>> [    1.340432] mrfevg:BAR0 start df100000 end df17ffff mmaped c3800000
> >>>>> [root@localhost mrmShared]# lsmod |grep mrf
> >>>>> mrf                    18421  0
> >>>>> uio                    19338  1 mrf
> >>>>> parport                46395  1 mrf
> >>>>> pci_mrfevg             53731  0
> >>>>> pci_mrfevr             53731  0
> >>>> It looks like you have two different drivers for MRF cards loaded.
> >>>> The Linux driver which is part of mrfioc2 is independent of, and
> >>>> conflicts with, all other Linux drivers for MRF cards.
> >>>> You should remove the pci_mrfevg and pci_mrfevr.  It would be best
> >>>> to reboot, then load only mrf.ko build from mrfioc2.
> >>>> If all goes well you should see a line like the following in the kernel log.
> >>>>> [   10.000000] mrf-pci 0000:02:01.0: MRF Setup complete
> >>>> https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/mrmShared/linux/uio_mrf.c#L675
> >>>>> Thanks
> >>>>>> -----原始邮件-----
> >>>>>> 发送时间: 2022-01-21 04:26:28 (星期五)
> >>>>>> 收件人: "[email protected]" <[email protected]>
> >>>>>> 抄送: "GAGET Alexis" <[email protected]>, "[email protected]" <[email protected]>[root@localhost
> >>>>>> On 1/20/22 7:31 AM, GAGET Alexis via Tech-talk wrote:
> >>>>>>> Hi,
> >>>>>>> I got this error a lot.
> >>>>>>> Many points :
> >>>>>>> - is the kernel module well loaded ? lsmod | grep mrf
> >>>>>> If the kernel module is being loaded, but the /dev/uio* devices
> >>>>>> are not being created, check the kernel log ("dmesg") for lines
> >>>>>> including "uio_mrf" and/or the specific PCI B:D.F.
> >>>>>>> - Depending on the CPU you use, you need to configure your PCIe virtual switch correctly.
> >>>>>>>     for me with NAT COMEx and NAT MCH it's like that (in the MCH webserver) :
> >>>>>>> With my configuration that is MTCA EVM300 andMTCA EVR300U I also had this problem because the CPU (NAT COMEX) hosting my EPICS IOC booted after the EVR and EVM. So the PCI configuration was not well done and produced this exact message you write below.
> >>>>>>> A manual solution is to reboot manually just your CPU to see if it's the problem. If it is, for me in the MCH (NAT MCH PHYS80) I have an argument "upstream slot power delay" that I put to 40 sec, meaning that my COMEx in RTM boot 40sec after the crate boot. (this work only with the latest version of the NAT MCH firmware)
> >>>>>>> ps : I prefer to use "lspci -nmmn" to list my PCIe device
> >>>>>> fyi. I keep a collection of lspci output from cards I've encountered.
> >>>>>> These were captured when correctly configured and running.  Maybe
> >>>>>> helpful as a point of comparison.
> >>>>>> https://github.com/epics-modules/mrfioc2/tree/master/documentation/lspci
> >>>>>>> Cheers
> >>>>>>> Alexis GAGET
> >>>>>>> CEA Saclay DRF/IRFU/DIS/LDISC
> >>>>>>> *De :* Tech-talk <[email protected]> de la part de gjzhai--- via Tech-talk <[email protected]>
> >>>>>>> *Envoyé :* jeudi 20 janvier 2022 14:52:33
> >>>>>>> *À :* [email protected]
> >>>>>>> *Objet :* mrfioc2-PCI device Configuration
> >>>>>>> Hello all I am trying to get MRF MTCA-EVG-300 and MTCA-EVR-300U configured and working on Linux using mrfioc2. I found geographic address(bus:device.function) in /proc/bus/pci/devices. The information is
> >>>>>>>     as follows:
> >>>>>>> 0800 10ee7011 10 df100000 0 0 0 0 0 0 80000 0 0 0 0 0 0 pci_mrfevg
> >>>>>>> 0900 10ee7011 11 df000000 0 0 0 0 0 0 40000 0 0 0 0 0 0 pci_mrfevr
> >>>>>>> According to the above information, my st.cmd in the iocevrmrm folder is defined as follows:
> >>>>>>> mrmEvrSetupPCI("MTCAEVR","09:00.0")
> >>>>>>> mrmEvgSetupPCI("EVG",08,00,0)
> >>>>>>> But the following error occurs:
> >>>>>>> Device MTCAEVR 9:0.0 slot=8
> >>>>>>> Using IRQ 17
> >>>>>>> Failed to open uio device for PCI device 0000:09:00.0: No such filleor directory
> >>>>>>> Can neither open resource file nor uio file of PCI device 0000:09:00.0 BAR 0
> >>>>>>> Error: invalid spec '08'
> >>>>>>> I use mrfioc2 2.3.0 . How deal with this problem?
> >>>>>>> Thank you for your time. I am looking forward to your reply.
mrfioc2-PCI device Configuration gjzhai--- via Tech-talk
RE: mrfioc2-PCI device Configuration GAGET Alexis via Tech-talk
Re: mrfioc2-PCI device Configuration Michael Davidsaver via Tech-talk
Re: mrfioc2-PCI device Configuration gjzhai--- via Tech-talk
Prev: Re: mrfioc2-PCI device Configuration Michael Davidsaver via Tech-talk
Next: Regarding an error ZALA ARYANSINH via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: ADCore R3-12 released Mark Rivers via Tech-talk
