Hello Julian,
The logbook factory setting should be “olog-es”. Apart from that, check the url, you might need to use “org.phoebus.olog.es.api/olog_url=http://localhost:8080/Olog”.
Cheers,
Juan
Gone through the installation instructions and set up both elasticsearch, mongodb, install for olog, and able to see the connection status on my web browser.
Afterwards I checked to make sure I am able to create logbooks, and log entry which was successful.
My issue is now trying to get it working on phoebus so I can create logs for my displays.
I thought adding the following to the settins.ini would have been enough, but it isn't:
org.phoebus.logbook/logbook_factory=olog
org.phoebus.olog.api/olog_url=localhost:8086/Olog
org.phoebus.olog.api/username=admin
org.phoebus.olog.api/password=1234
I get an error at startup:
WARNING [org.phoebus.logbook] Cannot locate logbook factory 'olog'
I'm not sure what else I am missing or mistake I am made. I would be grateful for any advise on how to proceed.
