Subject: |
Re: Phoebus-olog integration |
"Larregui, Julian via Tech-talk" <[email protected]> |
To: |
Date: |
Mon, 31 Jan 2022 21:18:50 +0000 |
Hello Juan,
Thank you for the reply. I made the necessary changes to the settings.ini, however the warning still pops up during startup.
I have an additional warning that shows up when right clicking my application and picking "Create Log":
WARNING [org.phoebus.ui.application.PhoebusApplication] Undefined logbook factory olog-es
Any idea on what my issue would be?
Thank you again for the assistance,
Julian
Hello Julian,
The logbook factory setting should be “olog-es”. Apart from that, check the url, you might need to use “org.phoebus.olog.es.api/olog_url=http://localhost:8080/Olog”.
Cheers,
Juan
Gone through the installation instructions and set up both elasticsearch, mongodb, install for olog, and able to see the connection status on my web browser.
Afterwards I checked to make sure I am able to create logbooks, and log entry which was successful.
My issue is now trying to get it working on phoebus so I can create logs for my displays.
I thought adding the following to the settins.ini would have been enough, but it isn't:
org.phoebus.logbook/logbook_factory=olog
org.phoebus.olog.api/olog_url=localhost:8086/Olog
org.phoebus.olog.api/username=admin
org.phoebus.olog.api/password=1234
I get an error at startup:
WARNING [org.phoebus.logbook] Cannot locate logbook factory 'olog'
I'm not sure what else I am missing or mistake I am made. I would be grateful for any advise on how to proceed.
- Re: Phoebus-olog integration Kasemir, Kay via Tech-talk
- Phoebus-olog integration Larregui, Julian via Tech-talk
- Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
Re: motor record field assignment problem Mark Rivers via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
