1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Connecting Basler camera with areaDetector on Windows
To: "Sullivan,Bryan" <[email protected]>
Date: Wed, 9 Feb 2022 21:04:36 +0000
Hi Bryan,
Unfortunately I don’t have the time or motivation to write a Pylon driver, since I don’t own any Basler cameras, and have no future need for them that I can foresee.
To write the driver you should use the ADSpinnaker, ADVimba, and ADAravis drivers as the model.  You basically need to write 2 classes:
PylonFeature  This extends the GenICamFeature class from ADGenICam.  This is the code to write/read GenICam features in the camera.  I assume that Pylon has a straightforward way to do that, the way that aravis, Spinnaker, and Vimba do.
ADPylon  This extends the ADGenICam class from ADGenICam.  This is the code to read the images, etc.
Sent: Wednesday, February 9, 2022 1:17 PM
Cc: [email protected]
Subject: Re: Connecting Basler camera with areaDetector on Windows
Hi Mark,
I'm running on windows because I'm building a control system in LabVIEW, and all the other elements in the system are setup on windows.
Writing a driver with the Pylon SDK seems like a promising solution. Would you be willing to put one together? Or if not, how would you recommend I start that process?
Bryan
Sent: Wednesday, February 9, 2022 11:38 AM
To: Sullivan,Bryan <[email protected]>
Cc: [email protected] <[email protected]>
** Caution: EXTERNAL Sender **
Hi Bryan,
The Windows support in aravis is very new.  The Windows GigEVision support was added less than a year ago, and I was not aware of it.  ADAravis and aravisGigE currently only work on Linux.
The aravis documentation does explain how to install aravis on Windows using msys2 (gcc) or using MSVC.  Once it is installed it should be possible change ADAravis to build with it on Windows, but it will definitely require work.
If there is not a strong reason to use Windows I would suggest using Linux instead.  It should just work out of the box.
Alternatively, the Basler Pylon SDK works on both Linux and Windows.  A driver using that SDK could be written, as I have done with ADSpinnaker and ADVimba for other vendor SDKs.
From: Tech-talk <[email protected]> On Behalf Of Sullivan,Bryan via Tech-talk
Sent: Wednesday, February 9, 2022 11:16 AM
To: [email protected]
Subject: Connecting Basler camera with areaDetector on Windows
I am trying to connect a Basler camera with areaDetector. I saw in a previous tech-talk (https://epics.anl.gov/tech-talk/2020/msg00388.php) that the aravisGigE and ADAravis modules should work with basler. I would prefer to use ADAravis since it is newer and better optimized, but when reading the documentation, I saw that ADAravis explicitly states that it cannot be used on windows because the underlying library aravis does not support it  (https://areadetector.github.io/master/ADAravis/ADAravis.html) but in the aravis documentation it gives instruction on how to install on windows (https://github.com/AravisProject/aravis).  Then with aravidGigE the documentation says it works on windows but then only gives instruction on how to install on lunix.
The questions I have are
  1. Can ADAravis be used on windows?
  2.
  3. Given a set of instructions for installing on lunix how can I adapt those to install on windows?
  4.
Bryan
Connecting Basler camera with areaDetector on Windows Sullivan,Bryan via Tech-talk
RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
Re: Connecting Basler camera with areaDetector on Windows Sullivan,Bryan via Tech-talk
Prev: Re: Connecting Basler camera with areaDetector on Windows Sullivan,Bryan via Tech-talk
Next: RE: PV Seq not process everytime GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: subtracting epicsTime variables Dudley, David via Tech-talk
