1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: error building asyn4-38 : cross_compiler_target_archs=linux-arm
From: "chaker.maazouzi--- via Tech-talk" <[email protected]>
To: <[email protected]>
Date: Wed, 16 Feb 2022 18:14:52 +0100
Hi
Sorry, but maybe my question will be a duplicate. but I can't find a
solution to my compilation error. My project is to integrate a redpitaya
module into my setup, I am trying to compile asyn4-38;
I using base3.16.2 :
I set in $(EPICS_BASE)/configure/CONFIG_SITE file
          CROSS_COMPILER_TARGET_ARCHS=linux-arm
          CROSS_COMPILER_HOST_ARCHS=linux-x86_64
 In file $(EPICS_BASE) configure/os/CONFIG_SITE.linux-x86.linux-arm  (called
in configure/os/CONFIG_SITE.linux-x86_64.linux-arm)  I set
GNU_TARGET = arm-linux-gnueabihf
GNU_DIR=/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-li
nux-gnueabihf
I add also after consulting the tech-talk website :
SHARED_LIBRARIES=YES
STATIC_BUILD=NO
compilation and building of the base is done without problem.
then i try to install asyn4-38 :
first I set in $(SUPPORT)/asyn4-38/configure/CONFIG_SITE file
After some errors(vxi11core_drv, rpcgen)  I install libtirpc-devel.x86_64
and rpcgen.x86_64 on my host
And uncomment TIRPC=YES in the same CONFIG_STE file
despite these actions I still get the error :                          ....
cannot find -ltirpc
[root@localhost support]# make
make -C ./configure install
make[1] : on entre dans le répertoire « /home/epicsmgr/support/configure »
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2] : on entre dans le répertoire «
/home/epicsmgr/support/configure/O.linux-x86_64 »
perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
make[2] : on quitte le répertoire «
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
/home/epicsmgr/support/configure/O.linux-arm »
checkRelease
make[1] : on quitte le répertoire « /home/epicsmgr/support/configure »
make -C ./asyn install
make[1] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38 »
/home/epicsmgr/support/asyn4-38/configure »
make[3] : on entre dans le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-x86_64 »
checkRelease
make[3] : on quitte le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-arm »
checkRelease
make -C ./makeSupport install
/home/epicsmgr/support/asyn4-38/makeSupport »
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-x86_64 »
make[3]: rien à faire pour « install ».
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-arm »
make[2] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38/asyn
/home/epicsmgr/support/asyn4-38/asyn/O.linux-x86_64 »
/home/epicsmgr/support/asyn4-38/asyn/O.linux-arm »
/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnue
abihf/bin/arm-linux-gnueabihf-g++ -o libasyn.so -shared -fPIC
-L/home/epicsmgr/support/asyn4-38/lib/linux-arm
-L/home/epicsmgr/base-3.16.2/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/support/asyn4-38/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/base-3.16.2/lib/linux-arm            -rdynamic
-L/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gn
ueabihf/arm-linux-gnueabihf/lib            asynManager.o
epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o
drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt64Base.o
asynInt64SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o
asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o
asynInt32ArraySyncIO.o asynInt64ArrayBase.o asynInt64ArraySyncIO.o
asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o
asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o
asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o
asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o
asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynOptionSyncIO.o
asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o
asynInterposeEos.o asynInterposeFlush.o asynInterposeDelay.o
asynInterposeEcho.o ParamListInvalidIndex.o ParamListParamNotFound.o
ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o
ParamValValueNotChanged.o paramVal.o asynPortDriver.o asynPortClient.o
devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o
devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o
devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o
devAsynFloat64Array.o devAsynFloat64TimeSeries.o devAsynInt64Array.o
devAsynInt64TimeSeries.o devAsynInt64.o asynRecord.o drvAsyn.o
vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o
devCommonGpib.o devSupportGpib.o boSRQonOff.o    -ldbRecStd -ldbCore -lca
-lCom  -ltirpc -lpthread    -lm -lrt -ldl -lgcc
abihf/bin/../lib/gcc/arm-linux-gnueabihf/6.3.1/../../../../arm-linux-gnueabi
hf/bin/ld: cannot find -ltirpc
collect2: error: ld returned 1 exit status
make[3]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_BUILD:292:
libasyn.so] Error 1
make[2]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_ARCHS:58:
install.linux-arm] Error 2
make[2] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38/asyn »
make[1]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84:
asyn.install] Error 2
make[1] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38 »
make: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84: asyn.install]
Error 2
Thank you very much for your attention to my problem.
Regards
Chaker Maazouzi
RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm Mark Rivers via Tech-talk
Prev: Re: Creating a database record Michael Davidsaver via Tech-talk
Next: RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Pheobus Alarm-System - Handling varying locations for associated displays Kasemir, Kay via Tech-talk
