1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [External] AW: phoebus alarm-logging UI blank
From: Paul Sichta via Tech-talk <[email protected]>
To: "Gotz, Malte" <[email protected]>
Date: Fri, 18 Feb 2022 12:55:07 -0500
Hello Malte,
Changing the es_host from an IP#  130.... to localhost made the UI work, thanks.   I thought I had tried that already, but your vote made me try again.
Some further googling revealed the SLF4J error message as a bug in m2e.
"The above error came after updating the m2e to version 1.1".  It should be fixed in v1.5
-ps
On Fri, Feb 18, 2022 at 4:47 AM Gotz, Malte <[email protected]> wrote:
Hello Paul,
your problem is more likely to be client side. Did you set the es_host preference? Since you see documents in the elastic index, the alarm-logging service is at least doing something.
Regarding the missing binding: It should not affect the functionality of the logger-service, just your ability to figure out if it has problems. Furthermore, the alarm-logger pom already has the slf4j-jdk14 dependency which provides the required binding. So, I don’t know why you are seeing this error.
>  I was hoping maven v3 isn't the problem.
Maven v3 should not be a problem. I am using maven 3.6.3 and it is working fine. Rather 3.0.5 might be a bit out of date.
Malte
Von: Tech-talk <[email protected]> Im Auftrag von Paul Sichta via Tech-talk
Gesendet: Donnerstag, 17. Februar 2022 23:15
An: [email protected]
Betreff: Re: phoebus alarm-logging UI blank
I should add I am using Maven 3.0.5.
The phoebus README said to use Maven 2.x .... but that uses http to access maven central plugins, so you get 501 code.
I also tried openJDK 11.0.2, same SLF4J issue
-ps
On Thu, Feb 17, 2022 at 12:23 PM Paul Sichta <[email protected]> wrote:
I cannot get the Alarm Log Table to show anything.  I'm using the default phoebus installation with the Accelerator topic, everything on localhost.
Versions:
current phoebus from git
openJDK 14.0.1
Kafka 2.12-2.4.0,  running zk and kafka in separate terminals
elasticsearch 6.8.4,  this running as a service
The kafka and alarm-logger terminals show the alarm events, and the Elasticsearch shows the indices:
curl -XGET localhost:9200/_cat/indices/
yellow open accelerator_alarms_cmd_2022-02-01    6fGn4YdqS-OfVnnzYl8-lQ 5 1    3 0  14.4kb  14.4kb
yellow open accelerator_alarms_config_2022-02-01 jPrWr4h-SYqr-yiW29W_fw 5 1   77 0 179.5kb 179.5kb
yellow open accelerator_alarms_state_2022-02-01  gF3U7_gpQSGf3zilts2nkQ 5 1 3991 0 544.3kb 544.3kb
What is suspicious: During maven build there is a complaint about SLF4J:
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ service-alarm-logger ---
[INFO] Building jar: /opt/phoebus/phoebus/services/alarm-logger/target/service-alarm-logger-4.6.6-SNAPSHOT.jar
[INFO]
[INFO] --- spring-boot-maven-plugin:2.1.6.RELEASE:repackage (default) @ service-alarm-logger ---
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
[INFO] Replacing main artifact with repackaged archive
[INFO]
[INFO] --- maven-assembly-plugin:3.2.0:single (make-assembly) @ service-alarm-logger ---
Do I need to add a dependency in the alarm-logger pom.xml file to get StaticLoggerBinder to be visible?
-ps
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
phoebus alarm-logging UI blank Paul Sichta via Tech-talk
Re: phoebus alarm-logging UI blank Paul Sichta via Tech-talk
AW: phoebus alarm-logging UI blank Gotz, Malte via Tech-talk
Prev: AW: phoebus alarm-logging UI blank Gotz, Malte via Tech-talk
Next: Error while installing the StreamDevice ZALA ARYANSINH via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Trying to create softIoc to group alarms in one variable Marco A. Barra Montevechi Filho via Tech-talk
