Hello! I used to use mrf-linux-driver from MRF. To load mrfioc2 IOC, I should delete pci_mrfevg and pci_mrfevr. [root@localhost mrmShared]# lsmod |grep mrf mrf 18421 0 uio 19338 1 mrf parport 46395 1 mrf pci_mrfevg 53731 0 pci_mrfevr 53731 0 As above, I want to delete pci_mrfevg and pci_mrfevr. I execute the following command to delete "pci_mrfevr.ko". [root@localhost]# cd /lib/modules/3.10.0-1160.42.2.el7.x86_64/extra/ [root@localhost]# rm pci_mrfevg.ko [root@localhost]# rm pci_mrfevr.ko After restarting, there are still pcievg and pcievr. Some of the information displayed by the dmesg command is as follows: [ 1.343665] pci_mrfevr: loading out-of-tree module taints kernel. [ 1.343997] pci_mrfevr: module verification failed: signature and/or required key missing - tainting kernel [ 1.344404] Event Receiver PCI/PCIe driver init. [ 1.344659] mrfevr:BAR0 start df200000 end df23ffff, mmap 03700000 [ 1.345275] mrfevr:BAR0 start df000000 end df03ffff, mmap 03780000 [ 1.345581] Event Generator PCI/PCIe driver init. [ 1.346094] mrfevg:BAR0 start df100000 end df17ffff mmaped 03800000 I would like to ask how to delete "pci_mrfevr.ko" and load mrfioc2 IOC successfully? Thank you for your time.I am looking forward to your reply.
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
