1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Timestamp test questions on Linux
From: Michael Davidsaver via Tech-talk <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Tue, 8 Mar 2022 23:05:05 -0800
On 3/7/22 00:47, gjzhai--- via Tech-talk wrote:
Hello!
I installed mrfioc2 2.3.0 on MTCA platform. According to EVR Usage Guide, when I do the timestamp test, there are two problems:
Could you describe your setup in more detail?
Where does the 1Hz (aka. 1 pulse per second) signal to the EVG
originate?  The same GPS receiver as the NTP server in question?
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evgMrmApp/Db/evgMrm.db#L93
a. The system is configured with NTP, but the current time provider does not have NTP
[opi@localhost ~]$ ntpstat
synchronised to NTP server (202.38.64.7) at stratum 3
    time correct to within 11 ms
    polling server every 512 s
b. The time interval between the system clock and the EVR time is large.
epics> generalTimeReport(2) Backwards time errors prevented 446106 times. Current Time Providers: "EVR", priority = 50 Current Time is 2022-03-07 16:34:25.575015. "OS Clock", priority = 999 Current Time is 2022-03-07 16:36:55.978638. Event Time Providers: "EVR", priority = 50
Thank you for your time. I am looking forward to your reply.
Re: Timestamp test questions on Linux gjzhai--- via Tech-talk
Prev: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Ashish Sharma via Tech-talk
Next: Andor3 issue connecting camera Sandeep Kumar Malu - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Timestamp test questions on Linux gjzhai--- via Tech-talk
Next: Re: Timestamp test questions on Linux gjzhai--- via Tech-talk
