Hi Abdalla,
Can you test if changing the "1 second" scanning to "10 second" changes the behavior?
I wonder if the asyn queue never gets empty because records process faster than the device allows, and I don't know what happens then. 10 second would give the queue more time. No idea
if that has any effect.
Dirk
Hi Mark
The HVPS is controlled via stream device, I attached the protocol file and the template database.
Best Regards,
Abdalla.
Hi Abdullah,
Is the code for the HVPS available on GitHub or somewhere else we can see it? We might be able to spot the problem.
Hi
We have an IOC to control two types of devices using stream device, a high-voltage PS from matsusada and a current pre-amplifier from SRS. The problem is that when typing exit on the IOC shell the IOC does not exit, so
I tried excluding devices from the IOC and it seems the problem is with the HVPS, when excluded from the IOC it exits normally and restarts under procServ. I enabled asyn masks using asynTraceMask and asyntraceIOMask, even after the exit the IOC is doing IO
with the device with no problem. I was using asyn 4.30 and stream 2.8.16 I think so I pulled the latest version of all drivers and still the same behavior.
Best Regards,
Abdalla.
- Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
- Re: Stream device IOC does not exit under procServ Mark Rivers via Tech-talk
- RE: Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Communication error Francisco Ramos via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
