1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Communication error
From: Francisco Ramos via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 10 Mar 2022 16:43:13 +0000
Hello community, I am writing to see if you can guide me in solving the following problem we are having.
We have an IOC compiled for VxWorks with EPICS version 3.13.9. We have simplified this IOC and its database has only one record "Analog Input" which you can see below.
record(ai, "iocE7:aiExample")
        field(DESC, "Analog Input")
        field(INP, "software:calcExample.VAL NPP NMS")
The problem we have is that we have created two softIOCs with the tool makeBaseApp.pl. One of them with the EPICS version (3.15.8.1-DEV-pdev2) and the other with the latest version of EPICS 7 (7.0.6.2-DEV). When the IOC communicates with the EPICS 7 softIOC (calc software:calcExample.VAL record), the iocE7:aiExample record cannot be processed. Below I show the output of the dbtr command of the iocE7:aiExample record, where you can see the STAT and SEVR fields.
ACKS: INVALID       ACKT: YES           ADEL: 0             ALST: 0
AOFF: 0             ASG:                ASLO: 1             BKPT: 0x00
DESC: Analog input  DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DTYP: Soft Channel  EGU: Counts         EGUF: 10
EGUL: 0             EOFF: 0             ESLO: 1             EVNT: 0
FLNK:CONSTANT 0     HHSV: MAJOR         HIGH: 6             HIHI: 8
HOPR: 10            HSV: MINOR          HYST: 0             INIT: 0
INP:CA_LINK software:calcExample.VAL NPP NMS                LALM: 0
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: MAJOR
LOLO: 2             LOPR: 0             LOW: 4              LSV: MINOR
MDEL: 0             MLST: 0             NAME: iocE7:aiExample
NSEV: NO_ALARM      NSTA: NO_ALARM      ORAW: 0             PACT: 0
PHAS: 0             PINI: NO            PREC: 0             PRIO: LOW
PROC: 0             PUTF: 0             ROFF: 0             RPRO: 0
RVAL: 0             SCAN: Passive       SDIS:CONSTANT       SEVR: INVALID
SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT
SMOO: 0             STAT: LINK          SVAL: 0             TPRO: 0
TSE: 0              TSEL:CONSTANT       UDF: 1              VAL: 0
However, when we deploy the softIOC with EPICS version 3.15.8.1-DEV-pdev2, the IOC (VxWorks) can communicate with the softIOC and the “iocE7:aiExample '' record is processed correctly. Both softIOCs have been deployed on the same machine. Ruling out that it is a problem with the machine itself.
Looking at the EPICS (3.13.9) code, in the line "if(!pca->chid || ca_state(pca->chid) != cs_conn)" of the dbCaGetLink function (dbCa.c file), the ca_state returns cs_never_conn (valid chid, IOC not found) when trying to communicate with the EPICS 7 softIOC. While in the EPICS (3.15.8.1) softIOC the returned value is cs_conn (valid chid, IOC was found, still available).
I don't know if EPICS 7 should be compatible with version ( 3.13.9 ), if not, I would appreciate if you could guide us on how to fix it. Right now we are not planning to migrate the subsystems we have compiled with that version of EPICS.
Thank you in advance.
Re: Communication error Michael Davidsaver via Tech-talk
Prev: AW: Stream device IOC does not exit under procServ Zimoch Dirk (PSI) via Tech-talk
Next: Re: Stream device IOC does not exit under procServ Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Next: Re: Communication error Michael Davidsaver via Tech-talk
