1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: Stream device IOC does not exit under procServ
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Mon, 14 Mar 2022 05:18:39 +0000
Hi Mark
It is connected via Ethernet and configured as
drvAsynIPPortConfigure(“HVPS”, “ip-address:7000”, 0, 0, 0)
Best Regards,
Abdalla.
Sent: Thursday, March 10, 2022 10:59 PM
To: Abdalla Ahmad <[email protected]>
Cc: [email protected]
Subject: Re: Stream device IOC does not exit under procServ
What is the physical interface to the HVPS, serial, Ethernet, etc?
Sent from my iPhone
On Mar 10, 2022, at 12:33 AM, Abdalla Ahmad <[email protected]> wrote:
Hi Mark
The HVPS is controlled via stream device, I attached the protocol file and the template database.
Best Regards,
Abdalla.
Sent: Wednesday, March 9, 2022 8:17 PM
Hi Abdullah,
Is the code for the HVPS available on GitHub or somewhere else we can see it? We might be able to spot the problem.
Sent from my iPhone
On Mar 9, 2022, at 12:00 AM, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Hi
We have an IOC to control two types of devices using stream device, a high-voltage PS from matsusada and a current pre-amplifier from SRS. The problem is that when typing exit on the IOC shell the IOC does not exit, so I tried excluding devices from the IOC and it seems the problem is with the HVPS, when excluded from the IOC it exits normally and restarts under procServ. I enabled asyn masks using asynTraceMask and asyntraceIOMask, even after the exit the IOC is doing IO with the device with no problem. I was using asyn 4.30 and stream 2.8.16 I think so I pulled the latest version of all drivers and still the same behavior.
Best Regards,
Abdalla.
Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Re: Stream device IOC does not exit under procServ Mark Rivers via Tech-talk
RE: Stream device IOC does not exit under procServ Abdalla Ahmad via Tech-talk
Prev: Re: Communication error Michael Davidsaver via Tech-talk
Next: odd ASYN behavior Runchey, John via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Stream device IOC does not exit under procServ Mark Rivers via Tech-talk
Next: Communication error Francisco Ramos via Tech-talk
