1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES
From: "Siddons, David via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tue, 15 Mar 2022 19:42:11 +0000
Hi Marco,
   Is EPICS_CA_MAX_ARRAY_BYTES set on both ends of the link?
Pete.
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, March 15, 2022 3:39 PM
To: [email protected] <[email protected]>
Subject: asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES
Hello all
Im debugging an EPICS asyn IOC which was working fine until now. The st.cmd of the IOC has a line which loaded asynRecord.db:
dbLoadRecords("$(ASYN)/db/asynRecord.db","P=$(DEV),R=asynEth,PORT=E873_ETH,ADDR=0,OMAX=256,IMAX=256")
and caput caget BL:H:EQ:asynEth.IFMT 1 (Hybrid)
caget BL:H:EQ:asynEth.BINP
in the IOC machine returned an array of numbers without any problem. However, it is recovering an array from a file much alrger than 256, so i suppose it just threw parts of the file away.
We wanted to get more of the file, so we raised IMAX to 350000 and defined the env variable EPICS_CA_MAX_ARRAY_BYTES=15728645. SO we got the error
caget MGN:A:E873:DIAG:A:asynEth.BINP
CA.Client.Exception...............................................
    Warning: "The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES"
    Context: "op=0, channel=MGN:A:E873:DIAG:A:asynEth.BINP, type=DBR_TIME_CHAR, count=16406, ctx="server unable to load read (or subscription update) response into protocol buffer PV="MGN:A:E873:DIAG:A:asynEth" max bytes=16408""
    Source File: ../getCopy.cpp line 92
    Current Time: Tue Mar 15 2022 16:32:11.936961493
Read operation timed out: some PV data was not read.
MGN:A:E873:DIAG:A:asynEth.BINP 350000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0  (the zeroes continue)
So we tried lowering IMAX to 16406 but still the error persisted:
MGN:A:E873:DIAG:A:asynEth.BINP 16406 0 0 0 0 0 0
does anyone know if we are doing something wrong or forgetting something? I dont think memory should be the problem here... Where do these "max bytes=16408" come from?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES Mark Rivers via Tech-talk
asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES Marco A. Barra Montevechi Filho via Tech-talk
Prev: asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Communication error Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: asyn IMAX data transfer exceeding EPICS_CA_MAX_ARRAY_BYTES Mark Rivers via Tech-talk
