1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: NDCodec Compression Factor
To: "Smith, William" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 Mar 2022 13:45:14 +0000
Yes, the lossless codecs like LZ4 and BZIP achieve very high compression with noiseless images, but much lower compression when noise is present.
Sent: Tuesday, March 22, 2022 8:13 AM
To: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Subject: RE: NDCodec Compression Factor
Ah ha! The noise parameter in my sim was non-zero as you suggest and playing with it shows that the compression factor I can achieve is dependant on it. Attempts with real images bear similar results.
Thanks for clarifying this for me,
Will
Sent: Tuesday, March 22, 2022 2:11 PM
To: [email protected]; Smith, William <[email protected]>
Hi Will,
Note that the current location of the documentation is here: https://areadetector.github.io/master/ADCore/NDPluginCodec.html
Please send screenshots of your simDetector configuration, e.g. simDetector.adl and simDetectorSetup.adl.  The performance you are seeing would be consistent with a non-zero value of the Noise parameter.
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Tuesday, March 22, 2022 2:03 AM
To: [email protected] <[email protected]>
Subject: NDCodec Compression Factor
I have been revisiting using the NDCodec plugin in areaDetector. I noticed that when I try to repeat the example shown here https://cars9.uchicago.edu/software/epics/NDPluginCodec.html under “Screen Shots” with the following parameters plugin
#NDCodecConfigure(const char *portName, int queueSize, int blockingCallbacks, const char *NDArrayPort, int NDArrayAddr, int maxBuffers, size_t maxMemory, int priority, int stackSize)
NDCodecConfigure("CODEC1", 20, 0, "SIM1", 0, 0, 0, 0, 0, 5)
With the same settings as is shows in the example:
Compressor: Blosc
Blosc Compressor: ZSTD
Blosc Comp. Level: 5
Blosc Shuffle: Bit
Blosc num threads: 6
I can only achieve compression of something like 1.3 not 151.35 as is shown in the example. What might I be doing wrong?
If I use JPEG compression I can achieve higher compression ratios, e.g with JPEG quality set to 10 I get compression factor of 81.5. With anything other than JPEG, for all combinations of settings I get roughly the same compression factor between 1 and 2.
The input image is coming from the sim detector. I am using a 1024x 1024 image of UInt8 which is a single peak centred about (500,500).
There is no codec error shown. I get no error in the ioc shell.
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
NDCodec Compression Factor Smith, William via Tech-talk
Re: NDCodec Compression Factor Mark Rivers via Tech-talk
RE: NDCodec Compression Factor Smith, William via Tech-talk
Prev: RE: NDCodec Compression Factor Smith, William via Tech-talk
Next: RE: Only one network interface of three NF CA5351 Current Amplifiers is accessible Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: EPICS Codeathon, 2022 Spring Edition [May 9-13] at SLAC Flath, Daniel L. via Tech-talk
