Do you mean that you are using the EPICS modbus module? If so, it is not possible to ignore the checksum, if it is wrong it will always generate an error. If the checksum is wrong then there is probably something wrong with your communications line or the
device firmware and you should try to fix it.
I believe that with StreamDevice you can just skip the checksum and it will not be an error.
Hi all,
I found it would be parse the response first no matter the checksum is right or error, no matter StreamDevice or modbus. Is there a good way to ignore the response or parse the record value as 0 when there happens checksum error?
Thanks in advance,
Jiaosai Li
- Re: About checksum error Maren Purves via Tech-talk
- About checksum error 李姣赛 via Tech-talk
How to integrate libcas fdManager with application's native main loop? Dmitry Yu. Bolkhovityanov via Tech-talk
ADViewer, EPICS_NTNDA_Viewer.java compilation Tomasz Brys via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
