1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: ADViewer, EPICS_NTNDA_Viewer.java compilation
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Fri, 25 Mar 2022 14:24:38 +0000
I want to compile EPICS_NTNDA_Viewer.java from the command line. I need it for my script which will automatize all the installation process of the areaDetector.
For the EPICS_AD_Viewer.java I simply used this command:
javac -cp ~/.imagej/plugins/jca-2.4.5.jar:/usr/share/java/ij.jar  ~/.imagej/plugins/EPICS_AD_Viewer.java
and plugin appears in imageJ.
I tried to do the same with NTNDA_Viewer by:
javac -cp ~/.imagej/plugins/jca-2.4.5.jar:/usr/share/java/ij.jar  ~/.imagej/plugins/EPICS_NTNDA_Viewer.java
but this doesn’t work. It complains for missing packages: pvaClient, pvdata etc.
I tried to put all of them in the command line but I did not succeed.
Can somebody help me with compilation of it?
/Tomasz Brys
BTW it works when I compile it from imageJ GUI but I want to do it from the command line.
Re: ADViewer, EPICS_NTNDA_Viewer.java compilation Mark Rivers via Tech-talk
Prev: Re: About checksum error Mark Rivers via Tech-talk
Next: Re: ADViewer, EPICS_NTNDA_Viewer.java compilation Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: How to integrate libcas fdManager with application's native main loop? Dmitry Yu. Bolkhovityanov via Tech-talk
