1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: cross-compiling Base 7.0.6 for win32
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: Freddie Akeroyd - STFC UKRI <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Mar 2022 20:08:28 +0000
Good point, I see that on my end as well.  And now that you mention it, I will look through our site-specific patch files to see if this is getting screwed up somewhere/
STATIC_BUILD is being set in configure/os/CONFIG_SITE.Common.win32-x86-mingw, as part of a patch that pre-dates my time here:
Date: Tue, 29 Dec 2015 11:41:22 -0800
Subject: Cross-build with mingw32
configure/os/CONFIG_SITE.Common.win32-x86-mingw    | 15 +++++++++++++++
configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw |  4 ++--
2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/configure/os/CONFIG_SITE.Common.win32-x86-mingw b/configure/os/CONFIG_SITE.Common.win32-x86-mingw
index ba19ac6..d2f74bb 100644
--- a/configure/os/CONFIG_SITE.Common.win32-x86-mingw
+++ b/configure/os/CONFIG_SITE.Common.win32-x86-mingw
@@ -5,3 +5,18 @@
# If readline is available uncomment the following line
# to enable command-line editing and history support
#COMMANDLINE_LIBRARY = READLINE
+CMPLR_PREFIX=i686-w64-mingw32-
+SHARED_LIBRARIES=NO
+STATIC_BUILD=YES
+# No -fPIC avoids "-fPIC ignored for target (all code is position independent)"
+SHRLIB_CFLAGS =
+SHRLIB_LDFLAGS = -shared -Wl,--out-implib,$(LIB_PREFIX)$*$(LIB_SUFFIX)
+LOADABLE_SHRLIB_LDFLAGS = -shared -Wl,--out-implib,$(LIB_PREFIX)$*$(LIB_SUFFIX)
+# Override linking with gcc library from CONFIG.gnuCommon
+GNU_LDLIBS_YES =
+OP_SYS_LDLIBS = -lws2_32
diff --git a/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw b/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
index dfc947e..cad5db1 100644
--- a/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
+++ b/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
@@ -15,9 +15,9 @@
 # Different distribution cross-build packages use different prefixes:
# Ubuntu:
-#CMPLR_PREFIX = i686-w64-mingw32-
+CMPLR_PREFIX = i686-w64-mingw32-
# RHEL:
-CMPLR_PREFIX = i686-pc-mingw32-
+#CMPLR_PREFIX = i686-pc-mingw32-
# Debian?
#CMPLR_PREFIX = i586-mingw32msvc-
I am not exactly sure why static build is necessary; there is no commentary along with the patch. Do you know of any reason why this would be required?
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Monday, March 28, 2022 3:59 PM
To: Daykin, Evan <[email protected]>; [email protected]
[EXTERNAL] This email originated from outside of FRIB
Hi Evan,
I’ve now tried a mingw build on Ubuntu 20.04 and found I didn’t need to make any changes, the  dbghelp  and psapi libraries are already listed in the  OP_SYS_LDLIBS  for mingw and this got automatically added to my link line when building tests and other things, but from the link line in your post this doesn’t seem to be happening. Which epics config file did you specify STATIC_BUILD in? I added this to CONFIG_SITE along with CROSS_COMPILER_TARGET_ARCHS and that all seemed to work for me with no additional libraries.
Freddie
Sent: 28 March 2022 20:37
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; [email protected]
Hi Freddie,
Yes, this fixed the initial problem. I also needed to add ‘psapi’ here and in modules/ca/src/client/Makefile. Thank you for your help! Almost done with a 7.0.6 Debian package now.
-Evan
Sent: Friday, March 25, 2022 8:05 PM
Hi Evan,
These functions are part of the “dbghelp” library that looks to be missing from your link line. I suspect that this library is needed in this case because it is a static build, for a shared (DLL) build it would have been linked into COM I expect. If you edit
    modules/libcom/test/Makefile
and change the PROD_SYS_LIBS_WIN32 line to be
PROD_SYS_LIBS_WIN32 += ws2_32 advapi32 user32 dbghelp
Does that help?
Freddie
From: Tech-talk <[email protected]> On Behalf Of Daykin, Evan via Tech-talk
Sent: 24 March 2022 18:55
To: EPICS tech-talk <[email protected]>
Subject: cross-compiling Base 7.0.6 for win32
Hi Tech Talk,
I am attempting to build Base version 7.0.6, with “CROSS_COMPILER_TARGET_ARCHS=linux-x86_64-debug win32-x86-mingw” on Debian 11, kernel version 5.10.0-8-amd64. I am getting the following error:
/usr/bin/i686-w64-mingw32-g++ -o epicsTypesTest.exe -static -L/user/daykin/git/epics-base/lib/win32-x86-mingw       -m32   -static-libgcc -static-libstdc++         epicsTypesTest.o    -lCom  -lws2_32 -ladvapi32 -luser32    -lws2_32
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x7b): undefined reference to `_imp__SymFromAddr@20'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0xf1): undefined reference to `_imp__SymSetOptions@4'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x118): undefined reference to `_imp__SymInitialize@12'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x1bd): undefined reference to `_imp__SymGetLineFromAddr64@20'
collect2: error: ld returned 1 exit status
I suppose this has something to do with the win32 API, but I’m not sure what I’m doing wrong; I have every gcc-mingw* package installed.  Has anyone experienced this before?
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email: [email protected]
cid:image002.jpg@01D07041.57B6D750
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
RE: cross-compiling Base 7.0.6 for win32 Freddie Akeroyd - STFC UKRI via Tech-talk
cross-compiling Base 7.0.6 for win32 Daykin, Evan via Tech-talk
RE: cross-compiling Base 7.0.6 for win32 Daykin, Evan via Tech-talk
Prev: RE: cross-compiling Base 7.0.6 for win32 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: RE: cross-compiling Base 7.0.6 for win32 Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
