Good point, I see that on my end as well. And now that you mention it, I will look through our site-specific patch files to see if this is getting screwed up somewhere/
STATIC_BUILD is being set in configure/os/CONFIG_SITE.Common.win32-x86-mingw, as part of a patch that pre-dates my time here:
Date: Tue, 29 Dec 2015 11:41:22 -0800
Subject: Cross-build with mingw32
configure/os/CONFIG_SITE.Common.win32-x86-mingw | 15 +++++++++++++++
configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw | 4 ++--
2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/configure/os/CONFIG_SITE.Common.win32-x86-mingw b/configure/os/CONFIG_SITE.Common.win32-x86-mingw
index ba19ac6..d2f74bb 100644
--- a/configure/os/CONFIG_SITE.Common.win32-x86-mingw
+++ b/configure/os/CONFIG_SITE.Common.win32-x86-mingw
@@ -5,3 +5,18 @@
# If readline is available uncomment the following line
# to enable command-line editing and history support
#COMMANDLINE_LIBRARY = READLINE
+CMPLR_PREFIX=i686-w64-mingw32-
+SHARED_LIBRARIES=NO
+STATIC_BUILD=YES
+# No -fPIC avoids "-fPIC ignored for target (all code is position independent)"
+SHRLIB_CFLAGS =
+SHRLIB_LDFLAGS = -shared -Wl,--out-implib,$(LIB_PREFIX)$*$(LIB_SUFFIX)
+LOADABLE_SHRLIB_LDFLAGS = -shared -Wl,--out-implib,$(LIB_PREFIX)$*$(LIB_SUFFIX)
+# Override linking with gcc library from CONFIG.gnuCommon
+GNU_LDLIBS_YES =
+OP_SYS_LDLIBS = -lws2_32
diff --git a/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw b/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
index dfc947e..cad5db1 100644
--- a/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
+++ b/configure/os/CONFIG_SITE.linux-x86.win32-x86-mingw
@@ -15,9 +15,9 @@
# Different distribution cross-build packages use different prefixes:
# Ubuntu:
-#CMPLR_PREFIX = i686-w64-mingw32-
+CMPLR_PREFIX = i686-w64-mingw32-
# RHEL:
-CMPLR_PREFIX = i686-pc-mingw32-
+#CMPLR_PREFIX = i686-pc-mingw32-
# Debian?
#CMPLR_PREFIX = i586-mingw32msvc-
I am not exactly sure why static build is necessary; there is no commentary along with the patch. Do you know of any reason why this would be required?
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Monday, March 28, 2022 3:59 PM
To: Daykin, Evan <[email protected]>;
[email protected]
Subject: RE: cross-compiling Base 7.0.6 for win32
[EXTERNAL] This email originated from outside of FRIB
Hi Evan,
I’ve now tried a mingw build on Ubuntu 20.04 and found I didn’t need to make any changes, the dbghelp and psapi libraries are already listed in the OP_SYS_LDLIBS for mingw and this got automatically
added to my link line when building tests and other things, but from the link line in your post this doesn’t seem to be happening. Which epics config file did you specify STATIC_BUILD in? I added this to CONFIG_SITE along with CROSS_COMPILER_TARGET_ARCHS and
that all seemed to work for me with no additional libraries.
Freddie
Hi Freddie,
Yes, this fixed the initial problem. I also needed to add ‘psapi’ here and in modules/ca/src/client/Makefile. Thank you for your help! Almost done with a 7.0.6 Debian package now.
-Evan
Sent: Friday, March 25, 2022 8:05 PM
[email protected]
Hi Evan,
These functions are part of the “dbghelp” library that looks to be missing from your link line. I suspect that this library is needed in this case because it is a static build, for
a shared (DLL) build it would have been linked into COM I expect. If you edit
modules/libcom/test/Makefile
and change the PROD_SYS_LIBS_WIN32 line to be
PROD_SYS_LIBS_WIN32 += ws2_32 advapi32 user32 dbghelp
Does that help?
Freddie
On Behalf Of Daykin, Evan via Tech-talk
Sent: 24 March 2022 18:55
To: EPICS tech-talk <[email protected]>
Subject: cross-compiling Base 7.0.6 for win32
Hi Tech Talk,
I am attempting to build Base version 7.0.6, with “CROSS_COMPILER_TARGET_ARCHS=linux-x86_64-debug win32-x86-mingw” on Debian 11, kernel version 5.10.0-8-amd64. I am getting the following error:
/usr/bin/i686-w64-mingw32-g++ -o epicsTypesTest.exe -static -L/user/daykin/git/epics-base/lib/win32-x86-mingw -m32 -static-libgcc -static-libstdc++ epicsTypesTest.o -lCom -lws2_32 -ladvapi32
-luser32 -lws2_32
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x7b): undefined reference to `_imp__SymFromAddr@20'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0xf1): undefined reference to `_imp__SymSetOptions@4'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x118): undefined reference to `_imp__SymInitialize@12'
/usr/bin/i686-w64-mingw32-ld: /user/daykin/git/epics-base/lib/win32-x86-mingw/Com.lib(osdFindAddr.o):osdFindAddr.c:(.text+0x1bd): undefined reference to `_imp__SymGetLineFromAddr64@20'
collect2: error: ld returned 1 exit status
I suppose this has something to do with the win32 API, but I’m not sure what I’m doing wrong; I have every gcc-mingw* package installed. Has anyone experienced this before?
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email:
[email protected]
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and
should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry
out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
