1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Prologix question
To: Eric Norum <[email protected]>
Date: Tue, 29 Mar 2022 16:58:29 +0000
Hi Eric and all,
We have been using a Prologix Ethernet/GPIB converter to talk to an older HP power supply.  It is generally working, but we see an infrequent problem (every few hours to every few days)
-          There is a timeout talking to the Prologix
-          When it recovers within a second or so the power supply briefly reports that it is over-voltage and over-current.
-          The power supply has turned off the output voltage.
We are facing a chicken and the egg question.  Did the power-supply glitch, and cause the Prologix communication timeout, or did the Prologix glitch and cause the power-supply to turn off?
Yesterday we switched to the older serial to GPIB converter, and that did not glitch for about 24 hours.  This device was previously used for several years before we bought the Prologix, and we don’t ever recall this issue with the power supply turning off the output voltage.
Today we are trying an Agilent E5810B VXI-11 gateway to see whether it glitches with that or not.
Have you ever seen a problem with glitches with the Prologix device?
Re: Prologix question Eric Norum via Tech-talk
Prev: Re: fanout Paul Sichta via Tech-talk
Next: Re: Prologix question Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: fanout Daykin, Evan via Tech-talk
