Hi John,
> Am I correct in assuming that if this was because the IOC lost its connection to the plc, this would be reported as an error in the IOC console [asynTraceMask is not explicitly set
so it is the default value of 1?]
Yes. Starting in Modbus R2-17 (September 2017) each Modbus asyn port driver
prints a single error message when a read operation from the PLC returns an error, and a single message when a read operation succeeds again.
Here is an example from when we were having some network issues recently:
[Tue Dec 21 12:06:01 2021] 2021/12/21 12:06:00.927 drvModbusAsyn::doModbusIO port K1_Yn_In_Bit error calling writeRead, error=164.54.160.197:502 read error: S_errno_EWOULDBLOCK, nwrite=6/6,
nread=0
[Tue Dec 21 12:06:01 2021] 2021/12/21 12:06:01.027 drvModbusAsyn::doModbusIO port K1_Yn_In_Bit writeRead status back to normal having had 1 errors, nwrite=6/6, nread=6
No documentation directory but if I look at modbusInterpose.c I see that it matches commits up to June 28,2019 which would make it 3-0 !
If ii is older look in release notes in documentation directory.
Sent from my iPhone
Look at the RELEASE.md in the top level directory.
Sent from my iPhone
Funny you should ask. I am looking at this IOC built by someone else and modbus is installed with no obvious version label. Any easy well to tell?
John
What version of the Modbus module?
Sent from my iPhone
All,
We have a WAGO plc which we read via modbus. There are just 18 PVs in this IOC, read as two blocks from the plc. All the PVs briefly go invalid for ~ 5 seconds (as reported by clients like Alarm Server, Archive Appliance)
Am I correct in assuming that if this was because the IOC lost its connection to the plc, this would be reported as an error in the IOC console [asynTraceMask is not explicitly set so it is the default value of 1?]
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
