1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Waveforms in Archiver Appliance
From: Michael Davidsaver via Tech-talk <[email protected]>
To: John Dobbins <[email protected]>
Date: Thu, 21 Apr 2022 09:39:58 -0700
On 4/21/22 09:34, John Dobbins wrote:
Good to know.  We are running Base-7.0.2.  I am guessing the problem was on the Archiver end. I don't know how that was built/deployed.
It is the Archiver end, which inherits this from JCA.
https://github.com/epics-base/jca/issues/35
John
*Sent:* Thursday, April 21, 2022 12:23 PM
*To:* John Dobbins <[email protected]>
*Cc:* [email protected] <[email protected]>
*Subject:* Re: Waveforms in Archiver Appliance
On 4/21/22 09:14, John Dobbins wrote:
Michael ,
It turned out to be the array size/EPICS_CA_MAX_ARRAY_BYTES.
Was this in the IOC or Archiver?
fyi. Base >= 3.16.1 doesn't use EPICS_CA_MAX_ARRAY_BYTES any more (by default).
https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md#epics_ca_max_array_bytes-is-optional <https://github.com/epics-base/epics-base/blob/7.0/documentation/RELEASE_NOTES.md#epics_ca_max_array_bytes-is-optional>
   I was only putting 50 values in the array but NELM =2048. Reducing NELM fixed the problem.
Also, thanks for the pointer to the policies info. I was wondering about that.
John
*Sent:* Thursday, April 21, 2022 12:07 PM
On 4/21/22 06:47, John Dobbins via Tech-talk wrote:
All,
Does the EPICS Archiver Appliance accept waveforms? The documentation suggests it does, but I was unable to add one (after initial sampling its status is 'not being archived').
You may be running afoul of a policy condition.
cf. the default policy.
https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py <https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py> <https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py <https://github.com/slacmshankar/epicsarchiverap/blob/master/src/sitespecific/slacdev/classpathfiles/policies.py>>
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu <http://www.chess.cornell.edu> <http://www.chess.cornell.edu <http://www.chess.cornell.edu>> <http://www.chess.cornell.edu <http://www.chess.cornell.edu <http://www.chess.cornell.edu>>>
Waveforms in Archiver Appliance John Dobbins via Tech-talk
Re: Waveforms in Archiver Appliance Michael Davidsaver via Tech-talk
Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Prev: Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Next: AreaDetector: device with 3 network ports David Vine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Waveforms in Archiver Appliance Shankar, Murali via Tech-talk
