1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Eiger Stream API problems
To: "Miceli, Antonino" <[email protected]>
Date: Mon, 25 Apr 2022 16:13:35 +0000
Hi Nino,
Your medm screen shot shows that you are running ADEiger version 3.0.0.  There have been 2 releases of ADEiger since then, and both have entries in the release notes documenting that they address the problem you are seeing:
Release Notes
R3-2 (January 22, 2022)
* Improved the R3-1 fix for the race condition with the Stream interface.
  In R3-1 the ZMQ socket was always created, whether or not DataSource was set to Stream.
  This introduced a problem for users who want to use ADEiger to control the detector,
  but use another ZMQ client to receive the data.
  It caused the other client to only receive every other ZMQ message.
  Now the ZMQ socket is only created when DataSource is set to Stream, and it is
  deleted when DataSource is set to anything except Stream.  This allows use of other ZMQ clients.
R3-1 (November 18, 2021)
* Fixed a race condition with the Stream interface.
  - The detector sends the first message over the ZMQ socket as soon as the "arm" command is sent when starting acquisition.
  - However, the driver was not creating the ZMQ socket to receive those messages until after the "arm" command was sent.
    This was a race condition.  It was failing on an Eiger2 at APS sector 34.
  - This release creates the ZMQ socket before acquisition begins.
The problem was documented in this Github issue:
https://github.com/areaDetector/ADEiger/issues/47
It was fixed in these commits:
https://github.com/areaDetector/ADEiger/commit/690db9a13b4e58fbba231d4a6b7d004001223b25
https://github.com/areaDetector/ADEiger/commit/c6a69fabc1e4db5281999876faf4ea16c1d8d4b4
From: Tech-talk <[email protected]> On Behalf Of Miceli, Antonino via Tech-talk
Sent: Monday, April 25, 2022 10:50 AM
To: [email protected] >> EPICS Tech Talk <[email protected]>
Subject: Eiger Stream API problems
Hi
Has anyone see these errors with ADEiger like this?
eigerDetector:streamTask: failed to get header packet
eigerDetector:streamTask: got Strat packet, ignoring
See IOC and MEDM screenshots here:
It did not happen immediately after a fresh reboot of IOC, while it occurred after we took data for a while when the IOC gave some error message about the Stream Api. You can also see in the last photo that the Steam state shows "disabled" even though it was set to enable. This happened no matter I set the header detail to "None" or "Basic". As this issue happened, the number on image counter didn't update while the default FileWriter still wrote frames into hdf5 files.
(Ignore the autosave error).
Nino
Eiger Stream API problems Miceli, Antonino via Tech-talk
Prev: Re: Eiger Stream API problems Zimoch Dirk (PSI) via Tech-talk
Next: RE: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Olog Features Larregui, Julian via Tech-talk
