1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: areaDetector ImageJ EPICS_AD_VIEWER
To: "[email protected]" <[email protected]>, Petra Schwalbach <[email protected]>
Date: Fri, 29 Apr 2022 12:02:39 +0000
Hi Petra,
I think you have configured the ImageJ plugin and the NDPluginStdArrays plugins correctly.  The problem is that the StdArrays plugin is not getting callbacks from the simDetector driver.  I can think of 2 reasons for this:
  • The simDetector driver has not been told to start collecting images or it is not in "Continuous" mode.
  • The simDetector driver has not been told to do NDArrayCallbacks
Look at the screen shot of the simDetector here: https://areadetector.github.io/master/ADSimDetector/simDetector.html#screenshots.
Note that the Start button has been pressed so the "Collecting" message is displayed.  The "Array callbacks" menu is set to Enabled.  If both of those are set correctly for you, and NDStdArrays is still not getting callbacks, then please send a screen shot of your simDetector.adl.
From: Tech-talk <[email protected]> on behalf of Petra Schwalbach via Tech-talk <[email protected]>
Sent: Friday, April 29, 2022 6:21 AM
To: [email protected] <[email protected]>
Subject: areaDetector ImageJ EPICS_AD_VIEWER
Hello,
I can start succesfully ImageJ and select under plugins EPICS_areaDetector the EPICS AD VIEWER.
I see the message 'PVs is connected' in the the status window.
When I press the Start button  to begin displaying images, nothing happens.
You can see this behavior with the attached files. I tried it with 13SIM1:image1 and 13ARV1:image1 to get pictures from my camera.
You can notice that there are no values for NX, NY, NZ and Frames/s.
When you look at the NDStdArrays.adl, you notice the configuration of the array is not done, dimension and array size is 0.
What do I forget in the configuration or misconfigured?
Best regards
Petra
Petra Schwalbach                            [Petra%20Schwalbach][email protected]
Privat:
mobil 0151 58854122
Festnetz 06131 593275
Inst. f. Kernphysik, Uni Mainz          Tel.: 06131/39-25193
B1-Kollaboration                               Fax: 06131/39-22964
Johann-Joachim-Becher-Weg 45     http://portal.kph.uni-mainz.de/B1/
55099 Mainz
areaDetector ImageJ EPICS_AD_VIEWER Petra Schwalbach via Tech-talk
Prev: areaDetector ImageJ EPICS_AD_VIEWER Petra Schwalbach via Tech-talk
Next: Converter from PECL (or 62.5um ST) to 50um LC fiber Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
