Thanks, that was the problem. Setting copyArray=true makes the issue go away. Are there any adverse side-effects of doing so?
-----Original Message-----
[email protected]>
Sent: Tuesday, May 3, 2022 12:10 PM
To: Daykin, Evan <
[email protected]>
Cc: Mark Rivers <
[email protected]>;
[email protected]
Subject: Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1
[EXTERNAL] This email originated from outside of FRIB
On 5/3/22 08:52, Daykin, Evan via Tech-talk wrote:
> Hm… I am not explicitly calling release() anywhere. This is my processCallbacks function- everything else in my plugin, AFAIK, doesn’t access any shared resources.
I have half a memory that NDPluginDriver::endProcessCallbacks() "steals"* a reference
to the NDArray when copyArray=false.
https://docs.python.org/3/c-api/intro.html#reference-count-details
> void NDPluginTemperature::processCallbacks(NDArray *pArray){
> static const char *functionName = "processCallbacks";
> NDArrayInfo_t arrayInfo;
> if(pArray->dataType != NDUInt16){
> asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
> "%s:%s: Only UInt16 supported.", driverName, functionName);
> return;
> std::string lastCalFileName = this->calibrationFileName;
> getStringParam(this->calibrationFileNameIdx, this->calibrationFileName);
> if(this->calibrationFileName != lastCalFileName){
> this->processCalibrationFile();
> int arrayCallbacks;
> getIntegerParam(NDArrayCallbacks, &arrayCallbacks);
> if(arrayCallbacks==1){
> epicsTimeStamp before;
> epicsTimeGetCurrent(&before);
> NDPluginDriver::beginProcessCallbacks(pArray);
> this->pNDArrayPool->convert(pArray,&(this->inputArray), NDUInt16);
> if(NULL == this->outputArray){
> this->pNDArrayPool->convert(pArray,&(this->outputArray),NDUInt16);
> //unlock while the plug-and-chug happens. No shared resources are accessed at this time.
> inputArray->getInfo(&arrayInfo);
> this->unlock();
> this->doTemperatureConversion(this->inputArray, this->outputArray, &arrayInfo);
> this->lock();
> setIntegerParam(NDArraySizeX, (int)outputArray->dims[arrayInfo.xDim].size);
> setIntegerParam(NDArraySizeY, (int)outputArray->dims[arrayInfo.yDim].size);
> epicsTimeStamp after;
> epicsTimeGetCurrent(&after);
> double delta = epicsTimeDiffInSeconds(&after, &before);
> cout<<"Took "<<delta<<" s"<<endl;
> setDoubleParam(runTimeIdx, delta);
> NDPluginDriver::endProcessCallbacks(outputArray, false, true);
> callParamCallbacks();
> *From:*Mark Rivers <
[email protected]>
> *Sent:* Tuesday, May 3, 2022 11:37 AM
> *To:*
[email protected]; Daykin, Evan <
[email protected]>
> *Subject:* Re: NDArrayPool:reserve ERROR, reference count = 0, should be = 1
> *[EXTERNAL] This email originated from outside of FRIB*
> Hi Evan,
> That error probably means you have called NDArray::release() on an array whose reference count is already 0.
> Most plugins don't need to call release() because it is handled in the base class NDPluginDriver::endProcessCallbacks().
> Mark
> *From:*Tech-talk <
[email protected] <
mailto:[email protected]>> on behalf of Daykin, Evan via Tech-talk <
[email protected] <
> *Sent:* Tuesday, May 3, 2022 10:20 AM
> *To:*
[email protected] <
mailto:[email protected]> <
[email protected] <
> *Subject:* NDArrayPool:reserve ERROR, reference count = 0, should be = 1
> Hi,
> I am hoping there’s an AreaDetector plugin maven here…
> I have written a small AD plugin intended to convert our raw camera images into a temperature heatmap, based on a calibrated gain, emissivity and exposure time. To test it, I set up a SimDetector in “peak” mode. I connect my plugin to this simDetector image.
I can successfully capture and convert 3 frames. On the fourth frame, my test dies with the following error. Are there any common pitfalls that might cause this?
> NDArray.uniqueId=1
> Do temperature conversion start
> Took 0.0937809 s
> NDArray.uniqueId=2
> Took 0.0655851 s
> NDArray.uniqueId=3
> Took 0.0642867 s
> NDArray.uniqueId=4
> NDArrayPool:reserve ERROR, reference count = 0, should be >= 1, pArray=0x7f453c001d80
> Thread SimDetTask (0x5621bbbb0c80) can't proceed, suspending.
> Dumping a stack trace of thread 'SimDetTask':
> [ 0x7f45538ffab3]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsStackTrace+0x73)
> [ 0x7f45538f0216]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(cantProceed+0xc6)
> [ 0x7f4553197b08]: /lib/x86_64-linux-gnu/libADBase.so.3.11(_ZN11NDArrayPool7reserveEP7NDArray+0x78)
> [ 0x7f455305db37]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver21beginProcessCallbacksEP7NDArray+0x367)
> [ 0x7f455375df1e]: /home/daykin/git/areadetector-temperature/lib/linux-x86_64/libNDPluginTemperature.so(_ZN19NDPluginTemperature16processCallbacksEP7NDArray+0xae)
> [ 0x7f455305dd53]: /lib/x86_64-linux-gnu/libNDPlugin.so.3.11(_ZN14NDPluginDriver14driverCallbackEP8asynUserPv+0x1d3)
> [ 0x7f4553851155]: /lib/x86_64-linux-gnu/libasyn.so.4.38(_ZN14asynPortDriver25doCallbacksGenericPointerEPvii+0x1f5)
> [ 0x7f4553809974]: /usr/lib/epics/lib/linux-x86_64/libsimDetector.so(_ZN11simDetector7simTaskEv+0x4e4)
> [ 0x7f45538fa0bb]: /lib/x86_64-linux-gnu/libCom.so.3.15.9(epicsSnprintf+0x7bb)
> [ 0x7f4553387ea7]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xd7)
> [ 0x7f455349edef]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
> *Evan Daykin*
> Controls Engineer
> Facility for Rare Isotope Beams
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824, USA
> Tel. 517-908-7678
> Email:
[email protected] <
> *cid:
[email protected]*
