1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Can't create mutex semaphore: too many
From: "Luchini, Kristi L. via Tech-talk" <[email protected]>
Date: Mon, 9 May 2022 22:08:12 +0000
Hello,
I have a MVME6100 ioc running RTEMS that appears to be having a resource issue.  Does anyone recognize these error messages below and happen to know function call that I can add to the st.cmd to increase that resource? Do  I need to increase the number file descriptors?
If I reboot the ioc the message will go away and the iocs works fine, but after some period of time, a month or so, this message reappears and you can’t access pvs over CA, which I assume is because the iocs seems to be too busy spewing error messages.
Any help would be appreciated.
Kristi
Message from RTEMS ioc:
Cexp@ioc-in10-mp01>
Cexp@ioc-in10-mp01>Error on UDP RX 172.27.72.43:47591 -> 172.27.75.255:5076 at 46 : Can't create mutex semaphore: too many
epicsMutex::mutexCreateFailed()
0x00 ca024000 27000000 d5b37962 00000000  ..@. '... ..yb ....
0x10 c84f9922 00740000 00000000 00000000  .O." .t.. .... ....
0x20 0000ffff 00000000 d3130374 6370ff    .... .... ...t cp.
CAS: Client accept error: Too many open files in system (16)
Error on UDP RX 172.27.72.99:37311 -> 172.27.75.255:5076 at 46 : Can't create mutex semaphore: too many
0x00 ca024000 27000000 a5a77862 00000000  ..@. '... ..xb ....
0x10 ea850c38 004f0000 00000000 00000000  ...8 .O.. .... ....
  • Kristi
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Prev: Re: INFICON Transpector MPH Residual Gas Analyzer (RGA) - http GET requests. Andrew Johnson via Tech-talk
Next: Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
