Hi Mark and Florian,
You are great! It works perfectly.
Thanks, Han
On Tue, May 10, 2022 at 12:49 PM Florian Feldbauer via Tech-talk < [email protected]> wrote:
Hey Mark,
you are right...I just searched tech-talk for the solution I got.
https://epics.anl.gov/tech-talk/2020/msg00369.php
Andrew suggested the following change, which worked for me
Where the Makefile says something like
PROD_IOC = <iocname>
replace it with this:
PROD_IOC_linux-arm = <iocname>
PROD_IOC += $(PROD_IOC_$(T_A))
The second line is needed, because as you said the syntax is only
working for OS_CLASS not T_A.
Cheers,
Florian
Am 10.05.2022 um 21:46 schrieb Mark
Rivers:
Ø
<name>
I think this syntax only work for OS_CLASS,
not for target architecture (TA)
So it works for
PROD_IOC_Linux = <name>
But for linux-arm I think you need to do:
ifeq (linux-arm, $(findstring linux-arm,
$(T_A)))
endif
Hey Han,
yes, there is a way. I did this once too.
If I remember correctly you simply need to change the line
PROD_IOC = <name>
to
PROD_IOC_linux-arm = <name>
in your <ioc>APP/src/Makefile
HTH Florian
Am 10.05.2022 um 21:31 schrieb Han Lee
via Tech-talk:
I have an IOC, I want to compile it
with only target architecture, for example, linux-arm.
My host is linux-x86_64. EPICS base and modules can be
compiled through the standard method with Host and
target well with os/CONFIG_SITE.linux-x86_64.linux-arm.
But due to the specific libs, and
header files for this IOC, I want to exclude the host
compilation.
Is there any way to force to compile
this IOC only for target Archture?
Jeong
Han Lee, Dr.rer.nat
Staff
Scientist and Engineer
Lawrence
Berkeley National Laboratory
1
Cyclotron Road Mailstop
46R0161
Berkeley,
CA 94720, United States
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
NB 2/131 / Fach 125
D-44801 Bochum
Office: NB 2/134
Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163
Cell:+1-510-384-3868
- Only cross compile option Han Lee via Tech-talk
- Re: Only cross compile option Florian Feldbauer via Tech-talk
- RE: Only cross compile option Mark Rivers via Tech-talk
2 Open Positions at Gemini/NOIRLab Matt Rippa via Tech-talk
PI controller C-887 Jong Woo Kim via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
