1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re:AW: pv invalid using stream
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Mon, 16 May 2022 19:05:37 +0800 (CST)
Hi Dirk,
     Thank you for your answer.
     I thought my process again and the python program seems to be not  right for my purpose.
     I intended to make the program be a virtual device and communicated with IOC.
     I put the code below.
Liang
At 2022-05-09 16:17:57, "Zimoch Dirk (PSI)" <[email protected]> wrote:
Hello Liang,
It looks like your protocol is binary. That means it can contain any bytes as values. That does not mix well with Terminator=LF because LF (\x010) may be part of your data. The result would be a too short message.
If your messages have all the same length (11 bytes including a terminating LF?), I suggest to use MaxInput=11 instead of Terminator=LF.
 I would do it.
Using ExtraInput=Ignore and data ignoring formats like %*2r you disable much error checking. It is better to make sure that you get the correct data.
I am not sure %c,%s or others, which was right for these.  And I think "%*2r" was right for these. I would changed it after find the right %.
A more detailed description of your format (what are those bytes?) and c copy of your python program would help to answer the question if your protocol is right and if streamDevice is suitable or not. It is suitable for a lot of things.
Following was python program.  It continue sending and receiving message after the ioc started.
I wonder,
1)could I using the python program as the fake device. I mean device should have input and output message, IOC output the message and then received message. But the program run itself after IOC was started, I don't think the stream protocol was useful to it.
2)If i was wrong, how stream module working on the program?
3)do you have some other way about fake device or virtual device,which could used in epics ?
Here is the python code:
 import socket
import struct
import crcmod def crccreate(b,length): crc16_func = crcmod.mkCrcFun(0x18005, initCrc=0xFFFF, rev=True, xorOut=0x0000) return crc16_func(b[0:length]) def crccheckhole(b,length): crc16_func = crcmod.mkCrcFun(0x18005, initCrc=0xFFFF, rev=True, xorOut=0x0000) return hex(crc16_func(b[0:length]))==bytesToHex(b[length],b[length+1]) def crccheck(b,length): print('传过来的b,和lenght',b,' ',length) crc16_func = crcmod.mkCrcFun(0x18005, initCrc=0xFFFF, rev=True, xorOut=0x0000) return crc16_func(b[0:length]) == bytesToInt(b[length], b[length + 1]) def get_send_msgflowbytes(slave,func,register,length,data): if length!=4: pass else: # print('data',data) a = struct.pack('!bbbbf', slave, func, register, length, data) # print(len(a)) b=struct.pack('H',crccreate(a[0:8], length=8)) a=a + b # print(a) return a if __name__=='__main__': tcp_server_socket = socket.socket(socket.AF_INET,socket.SOCK_STREAM) # create socket tcp_server_socket.bind(('192.168.127.201',9011)) #bind address和receive port tcp_server_socket.setsockopt(socket.IPPROTO_TCP,socket.TCP_NODELAY,True) print('Waiting connecting') tcp_server_socket.listen(1) #max monitor values client_socket,client_addr= tcp_server_socket.accept() # create connection print('Someone has connected to this sever') data="" while True: b =client_socket.recv(10) print('receiving msg:',b) slave,func,register,length=struct.unpack('!bbbb',b[0:4]) # analys the binary data +=1 # the datapacket format was from protocol file of epics
### As the comment said, following part would be connection with protocol,but i have no idea about it. msg = get_send_msgflowbytes(slave, func, register, length, data) #create datapacket format which satisfy the requirment
print('sending msg:',msg) client_socket.send(msg) if data="" data="">
These sending and receiving was continued:
sending msg: b'\x05\x03\x01\x04A\x00\x00\x00W\x19'
receiving msg: b'\x05\x03\x02\x04@\xe0\x00\x00W '       # 7 byte?
sending msg: b'\x05\x03\x02\x04A\x10\x00\x00V\xef'
receiving msg: b'\x05\x03\x01\x04A\x00\x00\x00W\x19'   # 8 byte?
StreamDevice sets the record to INVALID severity when something goes wrong. It prints an error message when that happens which may help to understand the problem. Make sure that 'var streamError' is 1. Do you see any error messages?
StreamDevice does sets status UDF only if something does very wrong, e.g. the protocol has a syntax error or the asyn port does not exist. If the device only sends something that the protocol cannot parse, the status would be CALC, not UDF. Check if there are error messages when the IOC starts.
Dirk
Von: Tech-talk <[email protected]> Im Auftrag von ?????? via Tech-talk
Gesendet: Montag, 9. Mai 2022 10:46
An: [email protected]
Betreff: pv invalid using stream
Hi all,
     I have a python program( xxx.py ), which simulate a hardware( actually it was prepared for a can bus device ). The xxx.py uses TCP protocols.
     The xxx.py would produce data, I intend to do the comunication with PC-linux and epics using xxx.py.
     I means ask IOC get the value produced by xxx.py.
the xxx.py send and receive message like these:
sending msg: b'\x05\x03\x01\x04A \x00\x00V\xd3'
receiving msg: b'\x05\x03\x02\x04A\x10\x00\x00V\xef'
sending msg: b'\x05\x03\x02\x04?\x80\x00\x00N\xea'
receiving msg: b'\x05\x03\x01\x04A \x00\x00V\xd3'
sending msg: b'\x05\x03\x01\x04@\x00\x00\x00V\xe5'
receiving msg: b'\x05\x03\x02\x04?\x80\x00\x00N\xea'
sending msg: b'\x05\x03\x02\x04@@\x00\x00W\x02'
receiving msg: b'\x05\x03\x01\x04@\x00\x00\x00V\xe5'   # has some strange character?
sending msg: b'\x05\x03\x01\x04@\x80\x00\x00W\r'
receiving msg: b'\x05\x03\x02\x04@@\x00\x00W\x02'
sending msg: b'\x05\x03\x02\x04@\xa0\x00\x00V\xf4'
receiving msg: b'\x05\x03\x01\x04@\x80\x00\x00W\r'
sending msg: b'\x05\x03\x01\x04@\xc0\x00\x00V\xd9'
receiving msg: b'\x05\x03\x02\x04@\xa0\x00\x00V\xf4'
Question:
I created an example ioc, added the db and proto, added " drvAsynIPPortConfigure("PS1","127.0.0.1:9011") " and STREAM_PROTOCOL_PATH in st.cmd.
--db file:
record(ai, "temperature")
 field(DESC, "temperature in tank")
 field(DTYP, "stream")
 field(INP, "@HSPY.proto GetTem PS1")
 field(EGU, "degree")
 field(SCAN, "1 second")
--proto file:
Terminator = LF;
GetTem {
        in "%*2r%r%*4r";
        ExtraInput = Ignore;
Then I got in IOC:
---epics> dbpr temperature
ASG:                DESC: temperature in tank               DISA: 0
DISP: 0             DISV: 1             NAME: temperature   RVAL: 0
SEVR: INVALID       STAT: UDF           SVAL: 0             TPRO: 0
VAL: 0
---epics> dbtr temperature
record active
Question:
1) Another better tool than stream device?
2) Does the proto I the right?
3) why my temperatre pv was invalid undefined?
     4) the received message was not so regular, stream device suitable?
Could someone do me a favor. ioc was run in unbuntu PC, epics was 7.0.x.
Liang
pv invalid using stream 网易邮件中心 via Tech-talk
AW: pv invalid using stream Zimoch Dirk (PSI) via Tech-talk
Prev: Re: Regex support in StreamDevice. Li, Ji via Tech-talk
Next: Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: AW: pv invalid using stream Zimoch Dirk (PSI) via Tech-talk
Next: Device support of asyn port driver for system commands. Phillip A. Sorensen via Tech-talk
